Re: 440 in a 78 Dodge which frame holes
[Re: chargers777]
#2549948
09/14/18 01:20 PM
09/14/18 01:20 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I'll check tonight when I get home.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: chargers777]
#2550214
09/15/18 09:32 AM
09/15/18 09:32 AM
ric3xrt
Trumbauersville PA
Here's a photo of the D code Ramcharger before I swapped the G3 in to it. Big block 4x2 uses the back holes in the Crossmember.
With the 4x4 mounts you should be able to use the front holes, the bottom photo is of a 4x4 Ramcharger converted over to 4x2 and I used the 4x4 mounts in the SB hole(forward holes).
[Re: chargers777]
#2550254
09/15/18 11:43 AM
09/15/18 11:43 AM
ric3xrt
Trumbauersville PA
chargers777 as you look at MoparMarks Photo , the mounts top left are 4x2 and the ones top right are 4x4s
Not to sound like an A$$ or insult your intelligence , but , if you have the 4x4 mounts make sure the round hole goes over the oil pump...…..I've seen people make that mistake.
