Re: Breaking rockers - bad mistake [Re: AndyF] #2545679
09/04/18 03:03 PM
09/04/18 03:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I'm sure about cutting the Hughes rockers - it tells you EXACTLY where they'll break. There are places in the engine where a sharp edge is a bad idea (piston dome) but harmless. Where that cut was taken is the worst possible place to remove any metal (the center of a span stressed in tension), and more so leaving a sharp negative profile with a violent change in cross-section.
If you absolutely have to remove metal there, cut only to the minimum depth to assure clearance (don't be surprised if some rockers need more than others - an extrusion or casting isn't accurate from the mold down to .001"), then blend & radius the cut into the parent shape in all directions so that the original cut is invisible. I would polish it, but that's just my OCD.
Boffin Emeritus
Re: Breaking rockers - bad mistake [Re: polyspheric] #2546077
09/05/18 11:28 AM
09/05/18 11:28 AM
moparx Offline
moparx  Offline
in my opinion, a large diameter "ball nose" endmill would work good for clearancing rocker arms, instead of the sharp tip, normal, endmills usually used. less blending needed, and no sharp corners created, causing potential stress risers. has anyone done it this way ? if not, why ?
beer
Re: Breaking rockers - bad mistake [Re: AndyF] #2546090
09/05/18 11:43 AM
09/05/18 11:43 AM
New York
polyspheric Offline
polyspheric  Offline
New York
This^^^
Boffin Emeritus
Re: Breaking rockers - bad mistake [Re: moparx] #2546106
09/05/18 12:15 PM
09/05/18 12:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a special end mill mad u just to clearance
rockers if they needed it.. was a 1 1/2" with
a 1/8" radius at the bottom.. I could do a small
plunge cut in one shot
wave
Re: Breaking rockers - bad mistake [Re: moparx] #2546133
09/05/18 01:18 PM
09/05/18 01:18 PM
AndyF Online content OP
AndyF  Online Content OP
I imagine lots of people do it that way. I always use a bullnose or ball end end mill when cutting an area that will have tensile stress. That is just a common design practice.
Re: Breaking rockers - bad mistake [Re: AndyF] #2546150
09/05/18 01:45 PM
09/05/18 01:45 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Fly cutter with a generous radius
Re: Breaking rockers - bad mistake [Re: AndyF] #2546204
09/05/18 03:09 PM
09/05/18 03:09 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Funny with really high lift you can't start in the center of the valve, unless you plan on using the retainer as part of the rocker path too. Lol
Re: Breaking rockers - bad mistake [Re: AndyF] #2546258
09/05/18 04:12 PM
09/05/18 04:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It's not only a function of lift, but the actual length (not the rocker ratio) of the valve-side lever is X-important. A really long rocker (Gen-1 hemi exhaust) is moving almost vertically with low lift with a very short scrub path.
Boffin Emeritus
Re: Breaking rockers - bad mistake [Re: AndyF] #2546330
09/05/18 06:53 PM
09/05/18 06:53 PM
Idaho
LaRoy Engines Offline
Idaho
If you think you have to grind or cut the rocker arms, discover the real problem and fix that.
Re: Breaking rockers - bad mistake [Re: LaRoy Engines] #2546437
09/05/18 11:05 PM
09/05/18 11:05 PM
Washington
madscientist Offline
Washington
STICKY THIS SENTENCE^^^^^^^^^^^^^^
/THREAD
Re: Breaking rockers - bad mistake [Re: AndyF] #2546451
09/05/18 11:39 PM
09/05/18 11:39 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The "real problem" is apparently bad rocker arms. Way too often, they try to make a small change in an existing product (Olds V8 to Windsor, BBC to Ford L6) to save R&D, but they don't have anyone on staff competent to say "wait a minute, there are other differences...". Rocker arm geometry (not application) was settled engineering 300 years ago, they're not paying attention.
Don't modify them? Throw them away? And replace them with what? Ask the manufacturer "do these fit?" What answer do you think you'll get? Is Barton, T&D, and Jesel the answer for everyone?
We have tolerated crap from even the most expensive sources far too long to expect NEVER to get a part that needs adjustment, etc.
[/rant]
Boffin Emeritus
