Re: 71 Cuda rocker mld. ?
[Re: Little Detroit]
#2545460
09/04/18 12:53 AM
09/04/18 12:53 AM
Posts: 18,157 Mass
DAYCLONA
Mass
YES AND 69 DART ALSO. go to local chey dealer and get them cheap. I don't think so...Classic/OER has (71 Cuda) them for $275, NOS usually fetch $300-$450 So you can buy the Camaro ones and try to explain them off as factory prototypes?, or pony up for repros/NOS
[Re: DAYCLONA]
#2545552
09/04/18 10:51 AM
09/04/18 10:51 AM
Posts: 704 WV
Little Detroit
WV
like I said go to local Chevy dealer and order them, not classics, if im not wrong the Chevy moldings that Dayclona used for visual effect are for a rally Camaro, but not sure exactly what those are , the standard Camero are the exact same as 71 Cuda.the only difference I believe were the clips if I remember correctly , been a few years since I have bought any.
[Re: 5carguy]
#2545555
09/04/18 10:58 AM
09/04/18 10:58 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
The Camero that I built a few years ago looked to have the same one piece moldings. It was an R/S Z-28 Don't know if they are the same length.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
#2546060
09/05/18 10:53 AM
09/05/18 10:53 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
The Camaro molding has a totally different contour, narrower and approx. 3/4" longer. I have a buddies 69 in the shop we are cut and buffing and comparing to an NOS 71 Cuda set.
