What valve springs for summit 6401 #2545939
09/05/18 12:27 AM
09/05/18 12:27 AM
Colorado
67plymouthman Offline OP
Colorado
My motor is a 400 with 9.5:1, auto, in a b-body. WHAT spring works?
Re: What valve springs for summit 6401 [Re: 67plymouthman] #2545940
09/05/18 12:28 AM
09/05/18 12:28 AM
Colorado
Colorado
That's the 465-488 lift cam.
Re: What valve springs for summit 6401 [Re: 67plymouthman] #2546041
09/05/18 09:54 AM
09/05/18 09:54 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
crane 99839-16 springs set at 1.80" installed height are what I've used. these will work with stock retainers and maintain retainer to seal clearance. don't use stock springs.
Re: What valve springs for summit 6401 [Re: 67plymouthman] #2546217
09/05/18 03:20 PM
09/05/18 03:20 PM
an8sec70cuda Offline
Comp 911
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What valve springs for summit 6401 [Re: 67plymouthman] #2546222
09/05/18 03:27 PM
09/05/18 03:27 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I used the trickflow springs that were recommended by Summit (it was in a tab at the bottom for recommended parts on the Summit site)
