Mini starter question #2544837
09/02/18 11:14 PM
09/02/18 11:14 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
My fairly new Power master XS starter seems to have taken a crap. I have an old mini that i bought from Mancini Racing back in 2000. Used it on my SB's for a long while til i bought the Power master. Do old Mini's work well on BB's with 11:1 comp? Thanks
Re: Mini starter question [Re: mopar dave] #2544846
09/02/18 11:27 PM
09/02/18 11:27 PM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
I have a stock 5.2 magnum starter on my 10.8:1 493. It works perfect on my engine.
Re: Mini starter question [Re: mopar dave] #2544847
09/02/18 11:29 PM
09/02/18 11:29 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
It will work fine. I had a stock rebuilt starter on my 500 with 14:1. Cranked it fine.
[image][/image]
Re: Mini starter question [Re: sgcuda] #2544854
09/02/18 11:53 PM
09/02/18 11:53 PM
Mt Morris Michigan
Mt Morris Michigan
Ok cool. Im gonna use it then. Thanks guys
Re: Mini starter question [Re: mopar dave] #2544878
09/03/18 01:00 AM
09/03/18 01:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
One I threw new contacts in back in 98 from a warranty return “clicks won’t start” has spun all 3 of our 13 to 1 small blocks smile still in the car.
Re: Mini starter question [Re: J_BODY] #2544884
09/03/18 01:14 AM
09/03/18 01:14 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
In 1999(?) they went from a stud and nut to a wire plug-in so the earlier ones are easier to connect to an older car.
Re: Mini starter question [Re: 6pakdakota] #2544931
09/03/18 03:35 AM
09/03/18 03:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats what I use on my 493 also with 10.6 comp. No problems at all. Ron
Re: Mini starter question [Re: 383man] #2544972
09/03/18 10:54 AM
09/03/18 10:54 AM
Mt Morris Michigan
Mt Morris Michigan
Sounds like the mopar mini is a good one. I'm a little surprised the power master xs starter took a crap so soon. Not much use on it. Bought it about 5 yrs ago, but only has maybe one season use on it. Not an inexpensive starter either. My local starter/ alt shop told me to stay away from the power master mini alts. Must be same deal with their starters.
Re: Mini starter question [Re: mopar dave] #2545175
09/03/18 04:17 PM
09/03/18 04:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The factory Mopar units are actually real Denso starters and the aftermarket stuff is mostly Chinese rip offs twocents
What does your Powermaster do? Does it just click or is there no response at all when voltage is applied. If it just clicks you can just get a set of contacts for less than $20.00 and it will be like new again. I put contacts in probably over 100 starters in my career and that fixes 99.9% of them.
Gus twocents
64 Plymouth Savoy
Dana 60
Re: Mini starter question [Re: fourgearsavoy] #2545228
09/03/18 05:24 PM
09/03/18 05:24 PM
Mt Morris Michigan
Mt Morris Michigan
It was just clicking but after a few atemps it wouldnt do any thing and would lose power to the relay for a couple minutes at a time. Then would have voltage to relay again til i hit the start button again. Starter works on the bench but doesnt feel smooth like the mopar mini which is now on the car and working great. Thanks guys
Re: Mini starter question [Re: mopar dave] #2545705
09/04/18 04:01 PM
09/04/18 04:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a reman from Advanced.Been in my 65 440 12.5 since like 2000.Still cranks like a /6..My kid ran a 440 Source in his 413 with 10.5 and no problemn.I get them for a 360 Dodge van .Rocky
Chrysler Firepower
Re: Mini starter question [Re: therocks] #2545744
09/04/18 05:39 PM
09/04/18 05:39 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. This one spins the engine faster than the powermaster did. I let the car sit for 5hrs after running. I hit the start button without touching the fuel pedal and the 511 started right up and idled. Nice. With a sorted carb and a good starter im happy.
Re: Mini starter question [Re: mopar dave] #2546080
09/05/18 11:32 AM
09/05/18 11:32 AM
moparx Online content
moparx  Online Content
a guy always feels good [and relieved !] when a problem is finally sorted out. good for you !
beer
Re: Mini starter question [Re: mopar dave] #2546147
09/05/18 01:40 PM
09/05/18 01:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Stock factory mini starter. 15-1, 32 degrees on the crank trigger, started withe ignition on. 6 years coming up on 600 passes.
Doug
Re: Mini starter question [Re: dvw] #2546188
09/05/18 02:47 PM
09/05/18 02:47 PM
Mt Morris Michigan
Mt Morris Michigan
Nice. Good to hear and thanks again guys.
