Re: Tire/Rim upgrade?
[Re: sgcuda]
#2545428
09/03/18 11:28 PM
09/03/18 11:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you go to bigger fronts you just slow down your reaction time.. if I were you I'd get it on the track and see what happens..its gonna take a bit to get it to react right.. after I got my car to work right I went down on the rear tire dia
[Re: sgcuda]
#2545438
09/03/18 11:46 PM
09/03/18 11:46 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Mr P: I wasn't going to change overall diameter. If anything, maybe step up to a 27" front runner. I agree on the rears. Depending on my trap rpm, I might be playing with 32" or 33" tires.
[image][/image]
[Re: sgcuda]
#2545444
09/03/18 11:57 PM
09/03/18 11:57 PM
MR_P_BODY
The bigger dia the fronts are you slow your reaction(more tire on the starting line lights) try the car first before you start changing stuff
[Re: sgcuda]
#2545474
09/04/18 01:45 AM
09/04/18 01:45 AM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
I've been looking at 17" fronts too. Since the height of the tire is the same I am not sure it's worth the extra money. Decisions, decisions.
[Re: slantzilla]
#2545480
09/04/18 02:26 AM
09/04/18 02:26 AM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
I was contemplating going to 17's as they are 4.5" wide vs 3.5 for the 15's. I will use the same 26 or 27" diameter tire. I like the wider foot print and will probably pull the trigger
Ok
[Re: sgcuda]
#2545630
09/04/18 01:45 PM
09/04/18 01:45 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The only good reason to put 17" wheels on the front is if you have a late model or resto-mod type deal with a big brake package and need them for clearance. 24 or 25 on a tube chassis type deal. 27 or 28 on a stock front end setup. Bigger tires on the back for bigger power. If you don't need them, the big tires will slow you down. Big diameter tires will typically go on faster cars. Less tire RPM and a more favorable rear end ratio.
There's a reason there are limited options for 17" front tires.
