Coil over Shock preference #2542472
08/28/18 01:42 PM
08/28/18 01:42 PM
Chicago-area Illinois
4mopower Offline OP
4mopower  Offline OP
Which would you use, AFCO, Viking, other?
I will be using these on a rear half car with a 4 link and also on a Aftermarket front k-member conversion.
The car will be 90% street driven 10% track with 800hp gen 2 Hemi.
I hear good and bad about most brands, so just wanted to see what most use.
I know you can get better(ie:santuffs) might not be necessary or in the budget.
Shock preference
multiple choice, up to 1 choices
Votes accepted starting: 08/28/18 01:38 PM
You must vote before you can view the results of this poll.
Re: Coil over Shock preference [Re: 4mopower] #2542526
08/28/18 02:58 PM
08/28/18 02:58 PM
Strange double adjustable, as long as possible on the extended length up scope
Re: Coil over Shock preference [Re: 4mopower] #2542546
08/28/18 03:21 PM
08/28/18 03:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a OLD set of QA-1s 0n the rear of the
race car.. they dont make them any more but
they work very well with my 4 link and they
are just a single adjustable... I had them
rebuilt about 10 years ago.. I have Strange on
all 4 corners of the Rampage with a ladder bar
wave
Re: Coil over Shock preference [Re: 4mopower] #2542570
08/28/18 03:57 PM
08/28/18 03:57 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Given those choices - AFCO. We've used their Big Gun valving on some cars - that ate up normal off the shelf shocks like they weren't even there - with good results. Strange are also good. It doesn't take a ton of horsepower or potential 60' numbers to get to the point of needing some custom valving beyond what off the shelf shocks provide.
Settings for best results on the street and the track will be way different.
Street miles are hard on drag shocks. Maybe a set of cheapies for the street and a good set of DAs for the track.
Re: Coil over Shock preference [Re: 4mopower] #2542697
08/28/18 07:53 PM
08/28/18 07:53 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would have to go with Afco. Call and ask for Eric he will take care of you.
Re: Coil over Shock preference [Re: 4mopower] #2542757
08/28/18 09:45 PM
08/28/18 09:45 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Strange DA here too.
[image][/image]
Re: Coil over Shock preference [Re: 4mopower] #2542936
08/29/18 10:46 AM
08/29/18 10:46 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Afco on that list.
Doug
Re: Coil over Shock preference [Re: 4mopower] #2542943
08/29/18 11:01 AM
08/29/18 11:01 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Strange
Re: Coil over Shock preference [Re: 4mopower] #2542972
08/29/18 12:23 PM
08/29/18 12:23 PM
4mopower Offline OP
4mopower  Offline OP
I fogot about the Strange coil overs, looks like they should be on my list to look into.
Mr.Pbody you were able to make SA QA-1 work on your drag car? I have a pair of older SA QA-1's new in the box that I thought would not work for my application.
Re: Coil over Shock preference [Re: 4mopower] #2542973
08/29/18 12:26 PM
08/29/18 12:26 PM
4mopower Offline OP
4mopower  Offline OP
Do the Strange need custom valving also? Will they last on light street use?
Re: Coil over Shock preference [Re: 4mopower] #2542977
08/29/18 12:41 PM
08/29/18 12:41 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Afco. You did not ask, or mention it, but make sure you go double adjustable.
69 GTX 68 Road Runner
Re: Coil over Shock preference [Re: 4mopower] #2543216
08/29/18 08:49 PM
08/29/18 08:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they have been great with my car and 4-link
with Strange single fronts
Re: Coil over Shock preference [Re: 4mopower] #2543224
08/29/18 09:23 PM
08/29/18 09:23 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Afco, then:
Fast Shocks
Re: Coil over Shock preference [Re: 4mopower] #2545059
09/03/18 01:06 PM
09/03/18 01:06 PM
4mopower Offline OP
4mopower  Offline OP
Yes i will be looking at DA.
Im getting close to the point that i can measure for shock length.
Thanks guys for the input. I'll be sure to check out the other options.
Re: Coil over Shock preference [Re: 4mopower] #2545100
09/03/18 02:20 PM
09/03/18 02:20 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Been very happy with Viking shocks. Not so much with Aladin.
Re: Coil over Shock preference [Re: 4mopower] #2545105
09/03/18 02:23 PM
09/03/18 02:23 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I should mention that on the rear of my car runs a pair of 20 year old Koni doubles. An oil change has been all the maintenance they've ever needed. Car repeats 60 fts within thousandths on a 10.5 tire makes over 900hp.
Doug
