Hemi Gen2 Heads Finished! #2544956
09/03/18 09:16 AM
09/03/18 09:16 AM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hi guys, finally i've finished works on Hemi Gen2 Heads of a friend. I've needed to change a lot of things in these heads, seats, valve guides, intake, exhaust and chamber reworks. So I'm pretty happy with results so far.
Tonight heads are going to a flow bench.
Intake Runner
Intake Bowl
Exhaust Runners
Exhaust Bowl
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2544967
09/03/18 10:23 AM
09/03/18 10:23 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Looks like beautiful work to me! How long did it take?
Re: Hemi Gen2 Heads Finished! [Re: Hemi ragtop] #2544994
09/03/18 11:30 AM
09/03/18 11:30 AM
Thanks Man! Porting works (intake, exhaust and chambers) was did in 60 hours.
Best 1/8 mile ET
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2545418
09/03/18 11:13 PM
09/03/18 11:13 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Which heads are these and what are you expecting for flow?
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2545429
09/03/18 11:29 PM
09/03/18 11:29 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Looks sexy for sure.. hopefully they flow what you are expecting popcorn
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2545468
09/04/18 01:15 AM
09/04/18 01:15 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That is art right there.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi Gen2 Heads Finished! [Re: gsmopar] #2545523
09/04/18 09:37 AM
09/04/18 09:37 AM
These Heads are Hemi Aluminum 3614433 Twin Spark. I hope that they will flow around 400@.600... I should flowed them last night but I had no time. Will be tonight! laugh
Best 1/8 mile ET
Re: Hemi Gen2 Heads Finished! [Re: WHITEDART] #2545524
09/04/18 09:40 AM
09/04/18 09:40 AM
Thank you Brother! Looks sexy for sure! Tonight we will see if I will be happy or sad... lol
Best 1/8 mile ET
Re: Hemi Gen2 Heads Finished! [Re: Hemi_Joel] #2545529
09/04/18 09:57 AM
09/04/18 09:57 AM
Thanks Man!!! When I received these heads they was terrible! Just for you have any idea, springs locator was pasted with 3M glue, valve guides with excessive clearance, poor valve job, valve spring install height wrong... Terror movie!!!
Look at the picture and you will see spring locator was pasted!
Best 1/8 mile ET
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2545723
09/04/18 04:50 PM
09/04/18 04:50 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Very pretty looking work...all shined up and ready to rock.
Rich H.
Esse Quam Videri
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2550931
09/17/18 08:55 AM
09/17/18 08:55 AM
Sorry for the late guys but finally I've the flow numbers.
I'm very proud!!!
Best 1/8 mile ET
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2551060
09/17/18 02:08 PM
09/17/18 02:08 PM
I'm very proud!!!
Ish nix read or understands Portuguese confused grin
I'm assuming the chart on the left is exhaust and the intake is on the right side, what is the rest?
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2551392
09/18/18 08:42 AM
09/18/18 08:42 AM
Sorry man. the last column on the right is the flow at 28". Green is intake and Red Exhaust.
Best 1/8 mile ET
Re: Hemi Gen2 Heads Finished! [Re: 360tripleblack77] #2551812
09/19/18 04:18 AM
09/19/18 04:18 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
That looks superb! What are the benefits of the intake port standing D-shape? Is it for the port, or for swirl in the chamber? It seems you did not change the height of the ports, rather worked on the width? I have been through a porting job recently with a similar set of heads, but I did not change the entrance shape except for making rounder corners. These were MP heads with provision for dualplugs that I milled/drilled converted to the dual plugs. I have no idea of the flow, but should't be too far from yours. What sort of intake manifold will you use, and will that one have the ports assymetric as well? Is it for street use or racing? Thanks for sharing!
Re: Hemi Gen2 Heads Finished! [Re: Oyvind Mopar] #2551939
09/19/18 02:20 PM
09/19/18 02:20 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
smile
