Breaking rockers - bad mistake #2544625
09/02/18 01:40 PM
09/02/18 01:40 PM
AndyF Offline OP
AndyF  Offline OP
https://www.hotrod.com/articles/rescue-random-chrysler-rocker-failures-really-arent/
It is an interesting article but the bottom line is that the person who built the engine wasn't paying attention. Ended up costing a bunch of time and money over the years before they figured it out.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544635
09/02/18 01:56 PM
09/02/18 01:56 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
B3 racing Mike, makes custom shaft shims for your heads & cam combination. Instead of a bunch of stacked funky shims.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544685
09/02/18 03:22 PM
09/02/18 03:22 PM
Washington
madscientist Offline
Washington
I read that in the last issue. I just shook my head when they machined the spring pockets bigger. They didn't correct the geometry and made the rocker arm weaker.
And this guy is a pro.
He didn't fix a thing, and contrary to what Dave Hughes told me, yes Dave, your rockers need to be correct too.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544699
09/02/18 03:48 PM
09/02/18 03:48 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Never happened to me - my cat immediately detects any errors.
No one noticed that geo remark?
"Brandes’ method, at rest (valve closed, pushrod not lashed), the tip is centered over the valve-stem tip both longitudinally (edge-on) and laterally (side-on). Shim the shaft spacers and shaft pedestals as needed to get there. Using an adjustable checking pushrod and light checking springs, set the preliminary valve lash to zero, and adjust pushrod length to achieve minimum motion off-center through the cam cycle."
I've been doing this stuff for 40 years, and I have no idea what he said. I'll bet Marlan Davis didn't either.
Boffin Emeritus
Re: Breaking rockers - bad mistake [Re: polyspheric] #2544705
09/02/18 04:01 PM
09/02/18 04:01 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The Brandes method sounds like something that would/could be used for a stud mounded rocker, correct? As said, B3 for the shaft stuff if you aren't (and I'm not) skilled enough to move your shaft pedestals around to correct the pattern and sweep width.
Am I off on this?
Also, after reading the article I am wondering why we need a 1.540" OD spring for a .600 lift cam? Is it not taboo to clearance rocker arms? Does it not matter as much with a smaller cam?
Re: Breaking rockers - bad mistake [Re: AndyF] #2544719
09/02/18 04:51 PM
09/02/18 04:51 PM
AndyF Offline OP
AndyF  Offline OP
They did mix up pushrod length for a stud mounted rocker with an article on shaft mounted rockers which adds to the confusion. I'm not sure about cutting the Hughes rockers, I would not have done that. That cam didn't seem radical enough to require cutting the rocker arms. A stout beehive or the dual conical spring or a smaller spring of some type most likely would've fit. I'm also not a fan of adding the shims under the shafts. I've worked on a bunch of race engines over the years and I've never had to add shims under the shaft. So when I see that I wonder what is going on.
What I thought was interesting was the root problem. If someone came on here and said their engine was breaking rocker arms how many people would ask if the pistons were installed in the correct holes? That is what the root cause was but it isn't something I'd normally put on the top of the list of problems.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544726
09/02/18 05:10 PM
09/02/18 05:10 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would say that the root cause of this issue would be an outlier.
It reminds me of when my high school shop teacher gave me a good lesson by asking me to diagnose a car that was missing on one cylinder. He mentioned that it had new plugs. I checked the entire ignition system before going back a finding one of the new plugs had been dropped prior to installation and the gap was closed. The lesson is that if your hypotheses, or premise, assumes any false information you will be fighting the wrong battle to solve the problem at hand. In this case it was originally assumed that the engine was assembled correctly, yet eating parts at random? No, incorrect premise. Clearly something was not correct. Did they mention the original p-to-v clearance on the intakes?
Knowing that it was a mild cam and it wasn't spinning high rpm would these symptoms be indicative of a mechanical interference occurring? I guess the lesson is to keep that bore scope handy lol.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544733
09/02/18 05:20 PM
09/02/18 05:20 PM
P
Porter67 Offline
Porter67  Offline
P
Thats got to be one of the most pathetic articles ive read in a long time, good fodder for the chevy guys.
My take on the lesson learned is have at least one guy in your crew thats not a dumbass. If a build is known to eat rockers, hey lets keep replacing them vs pulling it down and finding the issue NOT.
IMO thats a first time assembler (not builder) rookie mistake, if the valve cuts in the piston are not symmetrical there is always a pattern to follow. And its so easy to lay rolled clay on a full bank, set a head on and turn one cycle and inspect.
I f up alot of things but my builds dont eat parts, they maybe get mocked up 4-5 times and gets the pan and intake pulled for inspection after the dyno but they never eat parts.
Builds dont eat rockers, I could take one that breaks and chalk it up to a bad part, more then one and its time to come apart.
I use a 1.46 diameter spring on a .680 lift cam on my street racer, that build here was crap from the gate.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544746
09/02/18 06:01 PM
09/02/18 06:01 PM
Washington
Washington
The beehive spring would give you some rocker clearance but it still doesn't fix the geometry issue.
As you say, that spring wasn't big enough to be a problem. The problem is the shaft is too low, and too close to the valve.
Move it up and away from the valve and any retainer would clear.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544761
09/02/18 06:39 PM
09/02/18 06:39 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Marlan Davis is an excellent reason not to read Hot Rod.
Boffin Emeritus
Re: Breaking rockers - bad mistake [Re: AndyF] #2544764
09/02/18 06:45 PM
09/02/18 06:45 PM
P
Porter67 Offline
Porter67  Offline
P
A reputation for breaking rocker arms.
Initially, Brandes thought it was a random, old-age-related problem.
Huh? The two contradict themselves.
They should stick to 318 powered dusters.
Sounds more and more like a road kill episode of trying to get a junker to make it home. The blind leading the blind.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544774
09/02/18 07:50 PM
09/02/18 07:50 PM
NY
B1duster Offline
B1duster  Offline
NY
It was running 11.3 with the pistons mixed up and still only broke a rocker occasionally. Seems like in the end they straightened out the original builders mistakes. I work with a guy that does body and paint on the side, whether he’s drinking or not.
Sometimes it’s a crap shoot
Re: Breaking rockers - bad mistake [Re: B1duster] #2544795
09/02/18 08:44 PM
09/02/18 08:44 PM
AndyF Offline OP
AndyF  Offline OP
Yeah the valve to piston clearance was probably just super tight. So it spun over by hand but had problems when the guy ran it out the back door. The original engine builder messed up the piston install and then he must not have bothered to check valve to piston. And evidently nobody else ever checked VP even after the problems they ran into.
I don't think the article said what heads are on the engine. I'm guessing they are either EZ or SR heads with an Indy dual plane intake? If it is screwed together correctly that combo should make 600+ hp.
Re: Breaking rockers - bad mistake [Re: AndyF] #2544797
09/02/18 08:49 PM
09/02/18 08:49 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
"Don’t mix Miller time with engine assembly time. "
Sums it up
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Breaking rockers - bad mistake [Re: AndyF] #2544800
09/02/18 08:56 PM
09/02/18 08:56 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Always use flattops with no reliefs so you bend all the valves, much easier to troubleshoot
I had a 318 with 360 heads that use to bust rockers, too much spring pressure for the stockers, used the MP HD ones and that fixed it.
Re: Breaking rockers - bad mistake [Re: Uberpube] #2544804
09/02/18 09:00 PM
09/02/18 09:00 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I seem to hear my Old Man talking..."Unbelievable".
Re: Breaking rockers - bad mistake [Re: AndyF] #2545073
09/03/18 01:22 PM
09/03/18 01:22 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Pete's Garage sent me a T-Shirt for pointing out the pistons were hung on the rods wrong. Look a #6 piston starting around 17:15
https://www.youtube.com/watch?v=4vDZjiKAAkQ&t=60s
Re: Breaking rockers - bad mistake [Re: AndyF] #2545079
09/03/18 01:31 PM
09/03/18 01:31 PM
AndyF Offline OP
AndyF  Offline OP
Good eye. It wasn't easy to see that they had put the piston on wrong in that video. I would've missed that detail.
Re: Breaking rockers - bad mistake [Re: AndyF] #2545643
09/04/18 02:01 PM
09/04/18 02:01 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
SMH.
Rich H.
Esse Quam Videri
Re: Breaking rockers - bad mistake [Re: AndyF] #2545669
09/04/18 02:35 PM
09/04/18 02:35 PM
P
Porter67 Offline
Porter67  Offline
P
Not impressed in the least by Petes vid there. In the first two minutes what he was saying is a head scratcher if a first timer needed to decide on a std or .040 piston and a rolling assembly. A rolling assembly makes me think of a armored division in display mode.
If hed use more then a $8 ring compressor made for farm tractors and beating the pistons in hed be able to put the upper rod baring half in the rod, it takes alot to knock out a new bearing shell on assembly.
Id have to use his T shirt to was my push mower.
