Gen 3 Turbo build Oil Pump? #2544738
09/02/18 05:38 PM
09/02/18 05:38 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Which pump Mellings standard or High Volume? thx matt
[img] [/img]
Re: Gen 3 Turbo build Oil Pump? [Re: clonestocker] #2544788
09/02/18 08:30 PM
09/02/18 08:30 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
what block?
Re: Gen 3 Turbo build Oil Pump? [Re: mcat4321] #2544826
09/02/18 10:32 PM
09/02/18 10:32 PM
Tucson, Arizona
Tucson, Arizona
6.1 Block
[img] [/img]
Re: Gen 3 Turbo build Oil Pump? [Re: clonestocker] #2545178
09/03/18 04:26 PM
09/03/18 04:26 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
6.1 definitely high volume..
actually any turbo should go HV but since you have piston oilers definitely
HV
Re: Gen 3 Turbo build Oil Pump? [Re: mcat4321] #2545442
09/03/18 11:52 PM
09/03/18 11:52 PM
Tucson, Arizona
Tucson, Arizona
Thank You smile
[img] [/img]
