What motor do I have 273 or 318?
#2544317
09/01/18 04:50 PM
09/01/18 04:50 PM
Posts: 306 NY
LTLBEE
NY
I just picked up a 1967 small block motor. Chevy guy I bought it from said he took it out of his friends 67 Barracuda. They think its a 318. The casting number on the block is 2806030-273-4 cast on 4-7-67. The number stamped on the front of the block under the head is C 318. I thought the casting number on the side of the block had the motor displacement in the number which is 273 but on the front the stamped number is 318. What makes it more confusing is the motor has the 273 adjustable rockers with the correct heads and date codes. How can I find out what I have?
Re: What motor do I have 273 or 318?
[Re: LTLBEE]
#2544319
09/01/18 04:55 PM
09/01/18 04:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
since you can't make a 318 out of a 273 casting, I'm gonna say 273.
Measure the bore. 3.625 vs 3.91
[Re: LTLBEE]
#2544325
09/01/18 05:21 PM
09/01/18 05:21 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Being 67 and adjustable rockers, I'd say 273. But who knows, maybe they just put the wrong numbers on the side or front since 67 was the first year for the LA 318, but not in a Barracuda I think. 67-68-69 where the last years for the A-body 273s. At least it's got the good steel crank. Only one way to tell....
After looking at those rockers again, they look added, retainers are too big for the springs and they too look bigger than stock, then the aluminum intake too. Somebody's been changing parts. What's the head numbers?
[Re: LTLBEE]
#2544334
09/01/18 05:56 PM
09/01/18 05:56 PM
Supercuda
About to go away
About to go away
up yours
Wrong number on the side, lol. Listen to what you said. Everything you point out, except the numbers on the side, can easily be changed after it left the factory. The casting numbers can't.
measure the bores, anything else is BS.
[Re: LTLBEE]
#2544336
09/01/18 06:00 PM
09/01/18 06:00 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Had a 67 Fury one owner since new that had a 318 Poly from factory.IIRC it was a real early build.Paid 75 bucks for it because timing jumped.New chain and my brther drove it for 3 years.Rocky
Chrysler Firepower
[Re: cudaman1969]
#2544340
09/01/18 06:05 PM
09/01/18 06:05 PM
Posts: 306 NY
LTLBEE
NY
After looking at those rockers again, they look added, retainers are too big for the springs and they too look bigger than stock, then the aluminum intake too. Somebody's been changing parts. What's the head numbers? The head numbers are 2658920 with the correct 67 date code. The motor had a LD4b manifold and Mallory Dual Point dist added but the cam is original. Can the adjustable rockers be used with the hydraulic lifters and cam?
[Re: Supercuda]
#2544348
09/01/18 06:19 PM
09/01/18 06:19 PM
Posts: 306 NY
LTLBEE
NY
measure the bores, anything else is BS. Its supposed to be a running motor so I really don't want to pull it apart to measure the bores unless I have to.
[Re: LTLBEE]
#2544371
09/01/18 07:14 PM
09/01/18 07:14 PM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
Go with the casting number, that's a 273 that someone stamped 318 on the front.
[Re: LTLBEE]
#2544390
09/01/18 08:33 PM
09/01/18 08:33 PM
RapidRobert
Can the adjustable rockers be used with the hydraulic lifters and cam? yes but you likely will need shorter pushrods (mockup & see what you have for preload/threads showing under rocker tip) which might not be as critical on a daily driver but see what you got & go from there. EDIT cup/ball end rods like the OE solid lifter pushrods. MORE EDIT after some brief thought, very likely you will need shorter ball/cup pushrods.
[Re: RapidRobert]
#2544419
09/01/18 10:26 PM
09/01/18 10:26 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
[quote] Can the adjustable rockers be used with the hydraulic lifters and cam? What makes you think it has a hydraulic cam? Since it IS a 273 block, it IS a 273 and would have solid lifters and adjustable rockers stock. If the cam is stock as you say then the rockers and pushrods should be correct.just remember it needs lash not preload.
[Re: elmor353]
#2544524
09/02/18 10:10 AM
09/02/18 10:10 AM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
The casting numbers tell the story, you have a 273. I have had several 273's. Up until 1968 they all came with solid cams and adjustable rockers. The 68 engine I have now, came with a hydraulic cam and stamped steel rockers like the 318's. 2 barrel engines were solid lifter also? Kevin
[Re: Twostick]
#2544535
09/02/18 10:45 AM
09/02/18 10:45 AM
Posts: 43,635 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
The casting numbers tell the story, you have a 273. I have had several 273's. Up until 1968 they all came with solid cams and adjustable rockers. The 68 engine I have now, came with a hydraulic cam and stamped steel rockers like the 318's. 2 barrel engines were solid lifter also? Kevin No. 273's went up to 1969, had a 69 Dart convertible with one in it, two barrel only in 68 and 69. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: elmor353]
#2544949
09/03/18 07:04 AM
09/03/18 07:04 AM
RapidRobert
As said definitely a 273 short block. that is a new one on me, stamping the front dr side of the 273 block with "318" & they kept the 273 solid lifter stuff. Any evidence of a restamping there?
[Re: RapidRobert]
#2545089
09/03/18 01:45 PM
09/03/18 01:45 PM
Posts: 306 NY
LTLBEE
NY
As said definitely a 273 short block. that is a new one on me, stamping the front dr side of the 273 block with "318" & they kept the 273 solid lifter stuff. Any evidence of a restamping there? Does not look like it was restamped.
[Re: LTLBEE]
#2545132
09/03/18 02:48 PM
09/03/18 02:48 PM
RapidRobert
Assembly line workers have their off days too (all I can think of).
