someone makes a special fuel pump reservoir for the efi that is just outside the tank---that way you dont have to cut into your tank---might be holley or carter-----someone here will know.....
That’s what they call the Command Center. Low pressure fuel goes into the sump and is delivered via high pressure. The are usually mounted in the engine compartment. Suggest he does a lot of research. There’s a lot of complaints on the FITEC Command Center. Edelbrock just came out with one.
Also, a lot of information on the FITEC users group on Facebook.
