wagon gas tank #2544022
08/31/18 10:52 PM
08/31/18 10:52 PM
Marysville, OH
mrploww Offline OP
mrploww  Offline OP
Marysville, OH
I have a '64 Belvedere wagon. I am going to be installing a Gen 3 Hemi and EFI over the winter. I am searching for pictures of a wagon gas tank so I can send it to a couple shops to see if they can make a custom EFI tank for me. I am trying to avoid dropping my tank just to take some pictures. Does anyone have pictures of a 62-65 station wagon gas tank?
Thanks!!
'64 Plymouth Belvedere 9 passenger surf wagon
Re: wagon gas tank [Re: mrploww] #2544036
08/31/18 11:25 PM
08/31/18 11:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you remove the LR wheel & the splash guard, it's right there at the LR corner. The problem with your idea is getting all the dimensions right; they have kind of a weird shape.
Re: wagon gas tank [Re: topside] #2544218
09/01/18 12:32 PM
09/01/18 12:32 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Lucky Costa from Hotrod Garage has a 66Fury Wagon. He installed a tank in the foot well in the back. He’s running a bigblock with future plans for a Fitec system. The install is on YouTube.
Abe Lincoln
Re: wagon gas tank [Re: mrploww] #2544250
09/01/18 01:36 PM
09/01/18 01:36 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
someone makes a special fuel pump reservoir for the efi that is just outside the tank---that way you dont have to cut into your tank---might be holley or carter-----someone here will know.....
Re: wagon gas tank [Re: savoy64] #2544587
09/02/18 12:43 PM
09/02/18 12:43 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
That’s what they call the Command Center. Low pressure fuel goes into the sump and is delivered via high pressure. The are usually mounted in the engine compartment. Suggest he does a lot of research. There’s a lot of complaints on the FITEC Command Center. Edelbrock just came out with one.
Also, a lot of information on the FITEC users group on Facebook.
Abe Lincoln
