Got it done today
#2544516
09/02/18 08:44 AM
09/02/18 08:44 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
The old 440 has still got some winning left in it . Went to local nostalgia drags today , fathers day . Weather was iffy and we lost 2 qualifiers to drizzle . 1 qualifier , 3 rounds of chicago shoot out then a final . Car ran 10.71-10.73 with 2 passes backed off for wins Air was good , second day of spring , git under 600 da in final . Those TF270 heads with dominator have woken this old short block up. About 1.7 tenths still with only .520 nett lift cam
Tex.
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Got it done today
[Re: tex013]
#2544520
09/02/18 09:10 AM
09/02/18 09:10 AM
Posts: 570 UK
rb446
UK
Thats some gain ....what did you have on there before head/carb wise? I got 5.2 tenths and 7mph from going from stock 906's to 260cfm 906's back in the day.....
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2544773
09/02/18 07:41 PM
09/02/18 07:41 PM
tex013
Sydney,Australia
Thats some gain ....what did you have on there before head/carb wise? I got 5.2 tenths and 7mph from going from stock 906's to 260cfm 906's back in the day..... I had CNC stealth heads, Victor intake, ProSysytems HP1000 carb . Best had been 10.88 mostly mid/high 10.90s Just swapped these off the 505 , haven't changed jetting . Sixties the same , 1.50 , but I now have 30"radials and leave @ 4000 tbrake . This motor always preferred the 28"radial , probably go a little faster if I refitted them but I have consÃstant traction with the 30s All you guys have been a great help over the years to get to this point Tex
