Re: D350 Rear Ratio?
[Re: Rhinodart]
#2544592
09/02/18 12:52 PM
09/02/18 12:52 PM
Posts: 2,106 Byron, NY
W.I.N. Racing
Byron, NY
there were three ratios available, 4.10, 4.56 and 4.88. none were "standard" there should be a label on the hood that will tell you what ratio came with the truck, also there is a tag in the diff cover.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: kenworth_goose]
#2545544
09/04/18 10:39 AM
09/04/18 10:39 AM
Posts: 43,523 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Probably a 4.10 as 3.54 would be the only other gear offered. There should be a data sheet affixed to the underside of the hood. That would be correct for the 89 and up trucks but the 3.54 wasn't available in the 1 tons until 89. Or until the cummins came out. OK, I stand corrected. My 84 crew cab dually has 4.10's, but I am sure they were changed at some point.
JB Rhinehart, Realist
A-Body's RULE!
[Re: W.I.N. Racing]
#2545844
09/04/18 09:25 PM
09/04/18 09:25 PM
W.I.N. Racing
Byron, NY
there were three ratios available, 4.10, 4.56 and 4.88. none were "standard" there should be a label on the hood that will tell you what ratio came with the truck, also there is a tag in the diff cover. ^^^This info came direct from a 1986 Dodge Service manual^^^ All ratios were spec'd by Eng/trans combo. Wait this just in...found my '92 service manual! First just for clarity... all specs below are for D350 DRW and a Dana 70. The gear options in '92 were...3.54, 4.1 and 4.56 This is due to the 46RH OD trans. 89-91 (non intercooled) had 3.07 with the 727 only and 3.54 & 4.10's with manual trans. All the above information is supported by the Chrysler service manuals for the given year stated.
