Trunk lock rod cover screw (LA built 1970 E-body) #2544000
08/31/18 09:49 PM
08/31/18 09:49 PM
Michigan, USA
sixpackman Offline OP
Michigan, USA
Hello,
What screw is used on a LA built 1970 Cuda trunk lock rod cover?? Restoration books show a different screw then what a Hamtramck built car has.
Any help would be appreciated.
Thanks,
Scott
Re: Trunk lock rod cover screw (LA built 1970 E-body) [Re: sixpackman] #2544003
08/31/18 09:57 PM
08/31/18 09:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No book in the world will show every possible screw actually used. twocents
What do yours look like?
Re: Trunk lock rod cover screw (LA built 1970 E-body) [Re: Alaskan_TA] #2544441
09/01/18 11:08 PM
09/01/18 11:08 PM
Michigan, USA
Michigan, USA
Buddy restoring my car found it in Dave Wises book. It show what Hamtramck and what LA used. Hamtramck is a Philip screw with a star washer, LA used a Philip screw with a head that has a molded in washer look. I don't have a picture and that's why I'm asking.
I'm doing a concours restoration on my 70 cuda 440-6 (vary early build). Previous owner owned a GM dealership and when he restored it filled the car with the wrong bolts/ screws etc..
This is the last thing I need to figure out / locate.
