Which EFI kit do I choose? #2542004
08/27/18 01:44 PM
08/27/18 01:44 PM
junction city oregon
V
viperblue72 Offline OP
V
I am currently building a 440 for my ramcharger with future goals of adding a turbo later on, being that I have an old rv turbo manifold. I’d like an efi kit that will be boost and e85 compatible later on down the road. I may change my mind on that and just get a kit that’s good for 600hp. What kit would you choose For future goals, and what would you choose for current combo? The combo is as follows.
440 .030
9.8 compression (forged Wiseco 2.05ch)
Scat h-beams
Ported sidewinder heads
232@050int. 236 ex.
.525/.545 lift hydraulic roller 112lsa
Rpm intake
1 7/8 headers.
4.56 gear
36” tire
Re: Which EFI kit do I choose? [Re: viperblue72] #2542017
08/27/18 02:13 PM
08/27/18 02:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Might want to look at the Holley HP or the Dominator
both will do all of what your asking and more.. both
are multi point
wave
Re: Which EFI kit do I choose? [Re: viperblue72] #2542033
08/27/18 03:02 PM
08/27/18 03:02 PM
Cab_Burge Online work
Cab_Burge  Online Work
You need to make sure that the EFI computer you select is compatible with either a 2 or 3 bar MAP sensor scope
Re: Which EFI kit do I choose? [Re: Cab_Burge] #2542040
08/27/18 03:10 PM
08/27/18 03:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Holley HP or Dom is capable
wave
Re: Which EFI kit do I choose? [Re: viperblue72] #2542116
08/27/18 06:37 PM
08/27/18 06:37 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
That edelbrock pro-flow xt looks to the best in terms of plumbing. 9.8 compression is pretty high for a turbo build. It will be responsive off boost, but won't make the overall jam of a lower comp motor.
Re: Which EFI kit do I choose? [Re: viperblue72] #2542410
08/28/18 12:05 PM
08/28/18 12:05 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Holley HP kit from me :^)
I also provide you with a free startup tune, a free link to my online training so you get familiar with the software, and I become your tech support guy. I would suggest going port injected now so you'll have the tuning flexibility. Contact me for a quote.
Remember your fuel system will change because EFI requires an EFI pump, good filters, regulator and a return line back to the tank.
fastmanefi.com
Re: Which EFI kit do I choose? [Re: Mopar_Rich] #2542422
08/28/18 12:16 PM
08/28/18 12:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I should have gone your way when I did my set
up.. I could use your tune on my 416" HP set up
wave
Re: Which EFI kit do I choose? [Re: viperblue72] #2542443
08/28/18 12:51 PM
08/28/18 12:51 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
EFIstore.com
Re: Which EFI kit do I choose? [Re: viperblue72] #2543025
08/29/18 02:04 PM
08/29/18 02:04 PM
V
V
I was able to purchase a FiTech 1200 power adder kit from a moparts memeber that saw my post and his plans changed directions. Hopefully this kit will work out well. Thanks for all the tips and advice
Re: Which EFI kit do I choose? [Re: viperblue72] #2543257
08/29/18 11:22 PM
08/29/18 11:22 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I went with a Holley HP set up first. I went down to take the training class at the Holley facility. After I left, I sold my HP and bought a Holley Dominator setup. A lot more input/outputs with it. Especially if you are going with a turbo setup, I would look at the Dominator setup. As far as where to buy it, buy where you are going to get the best support after the sale. The guy that I bought mine from is a member on here. He also has wicked fast Duster with a twin turbo set up on it. Lucky for me he is local if I have any questions, he is there to help. Support is a big factor with these things.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Which EFI kit do I choose? [Re: viperblue72] #2543334
08/30/18 05:03 AM
08/30/18 05:03 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I wish I had spoken up earlier about why you dont want an FI tech.,...this is a glorified throttle body system and not true multi point EFI.....With a turbo you really want multipoint to ensure even fuel delivery. A throttle body system has most of the drawback of a carb with fuel and air having to thru the manifold and separating, which is not a problem w multipoint because the intake only has air in it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Which EFI kit do I choose? [Re: viperblue72] #2543676
08/31/18 01:33 AM
08/31/18 01:33 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
You need to get in touch with "moparborn" ... he's running dual blowthrough FiTech's turbo on an A Engine.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Which EFI kit do I choose? [Re: viperblue72] #2543856
08/31/18 01:40 PM
08/31/18 01:40 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have the Fitech power adder on a 410 small block based on a 360 with a procharger. Technical support is everything on a system like this. Fitech technical support leaves a little to be desired. I got the bugs worked out and the system works great now but it was a real struggle for a while. Few of the issues I had is that they are sensitive to fuel pressure, the drivers for the injectors in the computer can not handle excessive fuel pressure, and the system does set codes but Fitech gives you little help in figuring out why these codes set. The pressure regulator they use is for a VW 1.8 engine, at the rated 650HP it will not return enough fuel at idle and the driver can get hot and shut down. It is picky about what distributor you use if you want the computer to control ignition timing, buy a MSD billet, only one I could get to work right. Wrap all the wiring harness with a braided sleeve, they are very sensitive to RF noise. After I got those bugs figured out it starts and runs great on pump gas and even gets decent fuel mileage. The hand held controller works well. Also the hand held unit may not have all the features activated, the tech guys had to help me activate certain functions.
Re: Which EFI kit do I choose? [Re: jwb123] #2543924
08/31/18 05:29 PM
08/31/18 05:29 PM
AndyF Offline
AndyF  Offline
You did a lot of R&D to make that system work. Not a lot of guys are going to have the knowledge to solve all of the problems that you solved.
When I read the complaints on the Holley Sniper forum it is fairly obvious that some people buy the kits thinking they are foolproof. The EFI kits on the market today are better than ever, but they aren't foolproof. Some of them aren't even expert proof!
Re: Which EFI kit do I choose? [Re: AndyF] #2543928
08/31/18 05:45 PM
08/31/18 05:45 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Question for you sir. For mechanically inclined folks who know their way around a computer, how hard is it to set up the Holley Sniper inc spark control? How many hours would you guestimate it would take to get the system set up to start, idle, and drive as it should? Not looking to get every last little bit out of it, just a basic good streetable setup. Thanks in advance
Re: Which EFI kit do I choose? [Re: mgoblue9798] #2543934
08/31/18 06:03 PM
08/31/18 06:03 PM
IL
furious70 Offline
furious70  Offline
IL
Do you mean just the software or the work to get a dizzy set up as well? For me (using Classic FAST not Holley stuff) the spark table was the easiest part because there was a host of online info and graphs/tables of what people have done to retune traditional dizzy advances. I just copied that and then backed some off in the MAP areas where I was in boost.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Which EFI kit do I choose? [Re: Mopar_Rich] #2543942
08/31/18 06:23 PM
08/31/18 06:23 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
fastmanefi.com
I would go with Rich
2011 Drag Pak Challenger
Re: Which EFI kit do I choose? [Re: mgoblue9798] #2543967
08/31/18 07:33 PM
08/31/18 07:33 PM
AndyF Offline
AndyF  Offline
It doesn't take very long to bolt in a Hyperspark distributor and set up the ignition table. The Hyperspark plugs into the Sniper connector but you need to connect one wire to switched 12v so that means you need to find a source and make a connector. The Hyperspark drops in at TDC and then you put the cap on and route the plug wires. The wizard creates a base table which should start the car and allow you to drive. If you have a laptop with the Holley SW on it then you can plug in and optimize the table. One gotcha is that the Hyperspark distributor didn't fit with my heads so it took me some time to grind clearance. The Hyperspark will fit Trick Flow heads but I have old RPM heads.
Re: Which EFI kit do I choose? [Re: viperblue72] #2543988
08/31/18 08:50 PM
08/31/18 08:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you have a combo that ran previously then it is easy to get going with EFI. I knew what my car liked for timing(locked out) and I had an idea of what air fuel ratios I wanted. I first used my EFI controller for ignition only(coil on plug) and still used a carb for fuel, then I rolled over the fuel control later. So I kind of had two "first start experiences" and they both went without a hitch. The ignition one was no trouble at all. I was expecting problems with the fuel side because it was so different, it started right up and I actually wasn't prepared for that lol. My first trip around the block turned into a 45-50 mile test drive. The first few miles were a little rough but the auto tune did a decent job of pointing things towards my preset air fuel ratios and I was good to go.
68 Barracuda Formula S 340
Re: Which EFI kit do I choose? [Re: mgoblue9798] #2544002
08/31/18 09:52 PM
08/31/18 09:52 PM
AndyF Offline
AndyF  Offline
One place to start is the old Edelbrock EFI tuning manual. It covers timing curves in more detail than any of the Holley instructions that I've seen. The file is too big for me to attach here but I think you can find it on the Edelbrock website or elsewhere on the internet.
