Re: Valvetrain noise, with vid. [Re: jung] #2543052
08/29/18 02:48 PM
08/29/18 02:48 PM
CA
jung Offline OP
jung  Offline OP
CA
Thanks everyone, very much appreciated! Fast68plymouth, thanks for clarifying the oiling for the roller tips...seems a bit marginal but I guess the sweep is pretty small. I was only running a half turn of preload, so will try dialing that up a little.
Pics here. By the by, the noise I'm trying to track is the noise that sounds like an exhaust leak. (It's not.)
Will report back after I've had a proper check for pushrod contact and tried it with a bit more preload.
Re: Valvetrain noise, with vid. [Re: jung] #2543076
08/29/18 03:38 PM
08/29/18 03:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looks like “rust” on those valve tips to me.
Try cleaning it up with some scotchbright.
The “usual” place for contact is right at the top of the pushrod tunnel, at the edge of the flat pad that’s cast there.
This would be when the valves are closed.
The pushrod will move away from that side of the hole, towards the valve cover as the valve opens.
I’ve seen a few occasions where there was contact on the valve cover side of the tunnel at full lift, but it’s not as common, and usually only affects one or two.
All of this is just on the intakes.
I’ve never seen the exhaust have any issues.
It looks like someone did something minor with a sanding roll in that tunnel.
The sanded finish is easier to see the witness marks in compared to the shiny machined finish.
Hard to see from the pic if those dark spots are from contact, or if they just never got hit by the sanding roll.
Might try the scotchbright there to see if it leaves more of a mat finish for future observations.
When the rockers are bolted down, much much side to side play is there, per pair?
My preference is to have at least .010, but less than .030.
If you don’t find evidence of contact, I’d put it back together and run it some.
The XE lobes are usually a bit noisy....... might just be that’s what you’re going to get.
Re: Valvetrain noise, with vid. [Re: fast68plymouth] #2543175
08/29/18 06:42 PM
08/29/18 06:42 PM
CA
jung Offline OP
jung  Offline OP
CA
That's incredibly helpful thanks. The 'rust' stuff just wipes off with a finger so no worries there... smile
I'll pop it back together and take a very close look where you described, if it's at the top, I should be able to see it. Will measure the side play on the rockers too - I haven't done that except just to feel there was some.
Will let you know how it goes, hopefully smoothly. I'm well overdue turning a wheel or two in anger. I'd settle for mild annoyance at this point....
Re: Valvetrain noise, with vid. [Re: jung] #2543614
08/30/18 10:15 PM
08/30/18 10:15 PM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
maybe the rocker shafts are in wrong, upside down. Oil ?? I don't see any
Re: Valvetrain noise, with vid. [Re: dart9ss] #2543621
08/30/18 11:03 PM
08/30/18 11:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most guys will think they have a lifter noise
when its a small exhaust leak.. believe me it
can happen to all of us.. happened to me and
I worked in the exhaust lab at Chrysler for
35 year and building headers.. it doesnt take
much for a leak.. also make sure your shafts
are on the right way.. there is a UP and front
on them
wave
Re: Valvetrain noise, with vid. [Re: jung] #2543661
08/31/18 12:33 AM
08/31/18 12:33 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
It sounds dry to me. You may be getting some oil up top but it may not be enough. If those rockers came with stands make sure there’s a relief in the base of the oil feed stand. Ours didn’t and it restricted the oil. Also make sure you’re getting plenty of oil from the cam by priming the pump with the rocker stand off the head. Watch out - oil should shoot out of the feed hole and clear the fender. If it just trickles out the cam bearing may not be installed correctly.
Re: Valvetrain noise, with vid. [Re: jung] #2543663
08/31/18 12:45 AM
08/31/18 12:45 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Far more experienced guys than me saying a little oil is enough, but my experience is that there should be WAY more oil than that up there. Running it without covers like that, I would think you should have an absolute mess on your hands in mere seconds. (???). I’ll watch & learn here.
popcorn
Re: Valvetrain noise, with vid. [Re: StealthWedge67] #2543673
08/31/18 01:17 AM
08/31/18 01:17 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You are getting Some oil but not nearly enough IMO. Could be the vid though, But it should look more like a Flood of oil when you blip the throttle, witch it doesn't. Agreed, look for witness marks on the pushrods.
Re: Valvetrain noise, with vid. [Re: jung] #2543913
08/31/18 04:41 PM
08/31/18 04:41 PM
CA
jung Offline OP
jung  Offline OP
CA
Gah now I'm paranoid about the oiling again. Will put it back together tonight and take another look. There's definitely oil coming out of the pedestals, pooling on the shaft under the hold downs and oozing out of the side of the rockers. Not as much as I've seen in a few other videos I've looked at though.
The shaft is entirely symmetrical as far as I can see - doesn't look like it should make any difference which way up it goes. Tried calling Harland Sharp now but they close early on Friday.
Re: Valvetrain noise, with vid. [Re: jung] #2543937
08/31/18 06:13 PM
08/31/18 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a notch at one end of each shaft.. that
notch has a direction that it should be pointed..
and the holes are pointed down
wave
Re: Valvetrain noise, with vid. [Re: jung] #2543944
08/31/18 06:24 PM
08/31/18 06:24 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
In addition to what PB said. Theres big holes for the shaft feed and small holes for the rocker feeds. Those little holes are offset from the big ones. You want the offset to be pointed towards the springs/exhaust.
Don't know about the Harland sharp rockers, but most rockers have a groove inside the body of the rocker that travels centered to the oil feed. if you reverse the shafts the feed gets cut off on about half the stroke of the rocker some what possibly limiting oil supply, but not cutting it off completely. Never had one on backwards so never saw it myself.
Re: Valvetrain noise, with vid. [Re: jung] #2543960
08/31/18 07:11 PM
08/31/18 07:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
The HS shafts are symmetrical.
There is no up or down, or front or back.
When you put it back together, start it up and let it idle for a couple minutes.
If you see a trail of oil running along the head out by the valve cover rail toward the back of the motor, and starting to fill in the area in that rear corner....... and then start to crest(or almost crest) the valve cover rail....... then the oil flow is fine imo.
When there isn’t enough up top, the first thing that happens is the pushrods/adjusters run dry and burn up.
Oil typically doesn’t come spraying out of those rockers when you have the factory “through the cam” oiling.
As I mentioned earlier, the only oil hole is at the underside by the adjuster screw.
With any other rocker I can think of, you’d have more oil flying around since they would have another set of holes either on top of the rocker, or feeding the roller.
Re: Valvetrain noise, with vid. [Re: fast68plymouth] #2544118
09/01/18 02:43 AM
09/01/18 02:43 AM
CA
jung Offline OP
jung  Offline OP
CA
Very much appreciated! Back together, I can get a 12 thou feeler gauge down the side of all the inlet pushrods up top by the pedestals, the actual clearance must be larger so looks like no contact.
There's beaucoup oil - through the shaft, out the hole by the adjusters and in a good river back down the head. Set the preload an extra 1/8 of a turn which did make a little difference.
The only thing I can see wrong is there's very little side play in the rockers, just a few thou at best. They're not tight and the spacers rotate freely, but i might try and get some slightly thinner shims.
Still a bit ticky, but will take it for a spin tomorrow and see how things go.
Re: Valvetrain noise, with vid. [Re: jung] #2544272
09/01/18 02:23 PM
09/01/18 02:23 PM
Harland Sharp recommends and wants .015 minimum side play at room temps, use a feeler gauge that is accurate to measure yours scope
I use from 1/8 to a max of 1/2 turn preload on any Mopar hydraulic lifters at room temps up
A lot of folks on here forget that the adjuster is on the lifter side of the rocker arm and the ratio of the rocker arms changes how much preload the valve sees work
Most adjustable rocker arms use a 3/8x24 thread per inch adjuster screw, which equals .04166 per revolution for that size adjuster screw. The larger 7/16x20 adjuster screw equals .050 per thread revolution work
If you do the math on either one 1/4 turn equals either .0105 on the 3/8 size adjuster screw and .0125 on the 7/16 adjuster. Most of the instructions I've read about hydraulic lifter preload says to use from .030 to .000 preload on the Hi Po high rev hydraulics lifter shruggy scope
Re: Valvetrain noise, with vid. [Re: jung] #2544440
09/01/18 11:06 PM
09/01/18 11:06 PM
So. Burlington, Vt.
So. Burlington, Vt.
As long as there is at least “some” side to side free play between the rocker pairs when the motor is at operating temp you’ll be fine.
