Re: 1989 318 running bad when outside temp gets colder
[Re: gregh]
#2543493
08/30/18 04:26 PM
08/30/18 04:26 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
Back in the old pre injection days the heat crossover in the intake manifold would get clogged with black crap. It would run bad cold. We would have to pull the manifold and dig out the junk with a coathanger. I dont know if that was still a problem in later models.
[Re: gregh]
#2543515
08/30/18 05:26 PM
08/30/18 05:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Before I did anything I'd get the computer codes.
Cycle the key on-off-on-off-on (without starting engine) then count the light flashes. the codes will be 2 digits. Usually you will see a 12 (one flash, a pause, then two flashes) and a 55 (five flashes, then a pause and five more flashes. there will be a longer pause between codes).
Tell us what you got.
[Re: gregh]
#2544714
09/02/18 04:31 PM
09/02/18 04:31 PM
Supercuda
About to go away
About to go away
up yours
33 is normal in a no AC vehicle. No VSS is probably most of your problem, and too cold a thermostat is the rest of it. VSS tell the computer if the truck is moving and how fast. Without it the computer has no idea and you start to see stumbles and stalls, especially when stopped. with 37 there I almost think it's a wiring issue and both VSS and TC codes are present. I seem to have a vague recollection about wires getting corroded back behind the battery causing issues. VSS screws into the trans at the speedometer cable connection https://tinyurl.com/y7omwhne
