Leaking valve covers when motor revved up ? #2543461
08/30/18 02:57 PM
08/30/18 02:57 PM
Badge Offline OP
Badge  Offline OP
I have a 360 small block. Oil pressure cold is 70 psi, oil is 10-30. I have checked the shafts for the rocker arms and the groove is down front on the left bank and down rear on the right bank. I switched back to stock stamped steel covers hoping that would help. Gaskets are glued to the cover only. Motor is a mid 1980's. Head milled .020, performance cam and springs. Stock type flat tappet lifters, pushrods and rocker arms. I am frustrated. Any suggestions appreciated.
Re: Leaking valve covers when motor revved up ? [Re: Badge] #2543462
08/30/18 02:58 PM
08/30/18 02:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you have a PVC system hooked up correctly?
Re: Leaking valve covers when motor revved up ? [Re: Badge] #2543481
08/30/18 03:34 PM
08/30/18 03:34 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
Yeah, sounds like high crankcase pressure. Does it do it when you have the oil cap off?
Re: Leaking valve covers when motor revved up ? [Re: Badge] #2543497
08/30/18 04:34 PM
08/30/18 04:34 PM
Badge Offline OP
Badge  Offline OP
I will check that. It has a stock filter looking canister with a 5/8" house outlet that I don't have hooked up.
Re: Leaking valve covers when motor revved up ? [Re: stumpy] #2543520
08/30/18 05:33 PM
08/30/18 05:33 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
This is where you should start.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Leaking valve covers when motor revved up ? [Re: Badge] #2543532
08/30/18 06:05 PM
08/30/18 06:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A correct PCV system starts with a vented breather cap on one valve cover and a PCV valve in the other connected to the intake manifold vacuum port or the large vacuum port on the base of the carburetor. This allows bypass pressure in the crankcase to relieved.
