Mopar #4876129 intake M.W stage 6 intake manifold
#2543118
08/29/18 04:47 PM
08/29/18 04:47 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Has anyone on here used that manifold? If so how did you like it and did it fit your motor and heads okay? Which block, RB or B, and which heads did you use? I'm hoping it will work on a B motor with 440-1 heads All help appreciated
Re: Mopar #4876129 intake M.W stage 6 intake manifold
[Re: Cab_Burge]
#2543170
08/29/18 06:38 PM
08/29/18 06:38 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I doubt you’re going to have much luck getting that to fit -1 heads on a low deck, considering that manifold is extra wide to be used on an RB block with stage 6 heads and no spacers.
Basically, it’s an extra wide RB manifold for raised runner heads that don’t incorporate an extended flange, that has a built in valley plate.
[Re: Cab_Burge]
#2543173
08/29/18 06:40 PM
08/29/18 06:40 PM
fast68plymouth
So. Burlington, Vt.
I've got one - on an RB running Indy EZ Max wedge ported heads. My guess is you really have the 337 intake.
[Re: Cab_Burge]
#2543197
08/29/18 07:25 PM
08/29/18 07:25 PM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
I'm hoping it will work on a B motor with 440-1 heads All help appreciated I think it's going to be considerably too wide for your application, and I do not believe that you're going to make that work. Not only is it RB width, but + a little extra width to work with stage 6s. B block max wedge doesn't have many choices, currently...
Rich H.
Esse Quam Videri
[Re: Cab_Burge]
#2543309
08/30/18 01:47 AM
08/30/18 01:47 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Thanks for the help to all How about using it on a RB block with either 440-1 heads or Eddy Victor M.W. heads on a RB block Both those heads have a raised intake face to accommodate the raised ports and still use an rb intake. For either of those heads on an rb block the 337 intake is the lowest height choice and it's a great intake but good luck finding one. I have one I'm using now and hope they make another run so I can buy one and put it on the shelf if I need it in the future.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: Cab_Burge]
#2543317
08/30/18 02:12 AM
08/30/18 02:12 AM
fast68plymouth
So. Burlington, Vt.
The only combination of heads and block where that manifold is a true “bolt on” situation is stage 6 heads on an RB block.
It’s designed for that combination, and doesn’t really fit anything else.
