Hellcat blower on stroked 6.1 base motor say 426ci
#2541208
08/25/18 12:00 PM
08/25/18 12:00 PM
Posts: 625 Indianapolis In. usa
Quickrunner
What do you think the limitations are for a hellcat blower on a 6.1 based motor all forged bottom end. Could it make 1000 hp on premium pump? There are a few kits coming available soon to bolt the hellcat blower to standard heads eagle and newer. Have been leaning towards a Whipple but this setup could interesting.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Hellcat blower on stroked 6.1 base motor say 426ci
[Re: Quickrunner]
#2542334
08/28/18 07:50 AM
08/28/18 07:50 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
What do you think the limitations are for a hellcat blower on a 6.1 based motor all forged bottom end. Could it make 1000 hp on premium pump? There are a few kits coming available soon to bolt the hellcat blower to standard heads eagle and newer. Have been leaning towards a Whipple but this setup could interesting. Bore on the 6.1 will be the limiting factor, they get thing over 4.07 Good tune, 400ish CI, Aftermarket main caps, 1000hp is with in reach. BGE heads are the better choice for boosted
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: gregsdart]
#2542375
08/28/18 11:09 AM
08/28/18 11:09 AM
Quickrunner
Those hellcat blowers are HEAVY! I have one, and it weighs over 115 lbs! So figure that into your choice. Wow thats more than I would have guessed. I was just tossing the idea of a hellcat unit now that there are adapter kits coming available. I still think the Whipple will be a better choice for my situation but have not pulled the trigger just yet.
[Re: Quickrunner]
#2542378
08/28/18 11:18 AM
08/28/18 11:18 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I would go whipple, start with low boost and have plenty more power on reserve when you get ready for it. Having to buy a hellcat blower, then buying a whipple when you want more power is going to be more expensive.
68 Barracuda Formula S 340
[Re: Quickrunner]
#2542447
08/28/18 12:57 PM
08/28/18 12:57 PM
Quickrunner
For sure only doing it once, I have very specific goal. Was exploring if the Hellcat blower would meet the goal.
[Re: Quickrunner]
#2542786
08/28/18 10:45 PM
08/28/18 10:45 PM
ric3xrt
Trumbauersville PA
Have you looked in to a Darton Sleeved 6.1 ?
[Re: ric3xrt]
#2542839
08/29/18 01:06 AM
08/29/18 01:06 AM
Quickrunner
Have you looked in to a Darton Sleeved 6.1 ? No, but I will now.
[Re: Quickrunner]
#2542903
08/29/18 08:45 AM
08/29/18 08:45 AM
ric3xrt
Trumbauersville PA
I've done 2 so far, one was 4.125 X 3.795 with a 6.25 rod, 406 CI RR worked out to 1.65ish and a comp height of 1.09, I thought this would of made a great Boosted engine, but it was built NA. Apache heads with 2.18 Intake Howards .600 lift cam Edelbrock EFI intake the 2nd we pushed the limit on the sleeve, Darton says max bore for the MID sleeve system is 4.155, but we went 4.185, with a Molnar NHRA 3.59 crank 6.3 Length rods . 395CI 1.75 RR and 1.12 Comp height, and they spin that thing HIGH.
you could in theory build a 460 with the Darton sleeves, 4.155 X 4.25 , with a 6 in rod you would need a 1.125ish comp height , with a 6.125 rod you'd need a hockey puck `1 inch ish, now a Carrillo Pro 66070H rod would be a good compromise 6.07 length. bad thing is those rods are about $300-400 each....but then again everything in this "bench Race" 6.1 is going to be costly
[Re: Quickrunner]
#2542991
08/29/18 01:06 PM
08/29/18 01:06 PM
Quickrunner
Cost wise, a 6.1 block (dont seem to see those for less than 1K), darton sleeves, and machine work would have to be getting close to aluminum block $$ wise would it not?
[Re: ric3xrt]
#2543013
08/29/18 01:47 PM
08/29/18 01:47 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
you could in theory build a 460 with the Darton sleeves, 4.155 X 4.25 , with a 6 in rod you would need a 1.125ish comp height , with a 6.125 rod you'd need a hockey puck `1 inch ish, now a Carrillo Pro 66070H rod would be a good compromise 6.07 length. bad thing is those rods are about $300-400 each....but then again everything in this "bench Race" 6.1 is going to be costly I think you'd have issues with that short of a comp height. Boost pistons require .250 minimum from the top of the Piston to the first ring groove. But like you said everything would be big money.
[Re: DemonDust]
#2543036
08/29/18 02:19 PM
08/29/18 02:19 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
I had Arrington bore and stroke my 6.1L to 7.2L and left it N/A. Kit was advertised as 600hp N/A, and it did dyno at 525rwhp. Saved the cost of the super-charger. Next time will go 7.0L with Super-Charger for around 800hp. This is in my 6spd Challenger daily driver, and it still gets 19mpg at 70mph. Can smack down a lot of expensive imports now!
Some people you just can't reach...
[Re: Quickrunner]
#2543039
08/29/18 02:26 PM
08/29/18 02:26 PM
Quickrunner
I dont think I would ever explore into anything with that short a comp height for my application. This is for drag week and its a street strip car, longevity and reliability are a big factor. Granted with a lofty goal of mid to high 8's but at the weight I will end up at on my demon its not crazy talk with aroung 426 ci. Ballpark 1000 hp at the crank should more than get it done in the chassis I have built. And I think it is doable with the right motor & blower combo.
[Re: Quickrunner]
#2543053
08/29/18 02:49 PM
08/29/18 02:49 PM
Suregrip
Fort Lauderdale, FL
You should be able to get 1000hp with a super charger from 7.0L built for a drag car. That Hellcat blower sounds too heavy though, there must be lighter ones...
[Re: Quickrunner]
#2543345
08/30/18 09:18 AM
08/30/18 09:18 AM
ric3xrt
Trumbauersville PA
Cost wise, a 6.1 block (dont seem to see those for less than 1K), darton sleeves, and machine work would have to be getting close to aluminum block $$ wise would it not? Jegs and Summit have the Mopar Alum blocks listed in the $4300-4500 range I'm sure you could find them a little cheaper somewhere else. the Darton MID Sleeves are about 1500-1600. Machine work would depend on if you can fins a local or have to sent it to Darton or one of the shops they recommend. a month ago I bought a 6.1 with 2 cracked cylinders for $100 but the going price seams to be $900-1500 for good block.
[Re: Quickrunner]
#2543347
08/30/18 09:24 AM
08/30/18 09:24 AM
ric3xrt
Trumbauersville PA
I dont think I would ever explore into anything with that short a comp height for my application. This is for drag week and its a street strip car, longevity and reliability are a big factor. Granted with a lofty goal of mid to high 8's but at the weight I will end up at on my demon its not crazy talk with aroung 426 ci. Ballpark 1000 hp at the crank should more than get it done in the chassis I have built. And I think it is doable with the right motor & blower combo. I think your goal is very archivable https://www.youtube.com/watch?v=PSBeSfrvko8 granted it's a NA 449 CI G3, weight is about your Demon's ball park.
[Re: fbs63]
#2543400
08/30/18 12:38 PM
08/30/18 12:38 PM
ric3xrt
Trumbauersville PA
Not to hijack the thread but any reason the Darton mid sleeves could not be put in a 5.7 block? I would think the cylinder walls will be completely bored out of the 6.1. Why not a 5.7? Honestly I don't see why they couldn't be used in a 5.7 block, and I wouldn't be surprised if someone hasn't already done it. There area few SBC and LS application sleeves that could be modified to work in the G3 block, I 'd like to try a few different combos when the funds are available
