Re: Quick Fuel 950 vs. Standard Holley HP?
[Re: dustyhof]
#254284
03/15/09 02:54 PM
03/15/09 02:54 PM
Posts: 12,407 Taxes & Virus's R-US, NY
Dragula
Yes, they are well worth the extra $...Not just the main body is contoured better, but the squirters, throttle blades, linkage are all slightly altered, and when its all combined, it really adds up. Fit and tolerences are better than any Holley I have had, and for what Holley gets for one, they should be better. I have had Holley metering blocks that were so pourous, you couldn't use them, yet they charge top dollar..No thanks. Ohhh and QFT has awesome customer support, how about Holley?
[Re: Dragula]
#254285
03/15/09 03:50 PM
03/15/09 03:50 PM
Posts: 502 Huron, South Dakota, United St...
dustyhof
Dumb question, but, do they still use standard Holley squirters for tuning purposes? Will my standard Holley tuning kit still work?
[Re: dustyhof]
#254286
03/15/09 07:36 PM
03/15/09 07:36 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Yes. I have a QF 750 on my Dart, very good carb with excellent customer service .
[Re: dustyhof]
#254287
03/15/09 08:11 PM
03/15/09 08:11 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Yes,all your Holley tuning parts will work,including squirters,pump cams,jets,and so on. I am pleased with my QFT 950.
[Re: VernMotor]
#254294
03/15/09 09:27 PM
03/15/09 09:27 PM
950 QF here..but order it from them.tell them your combo..there is a reason why they are cheaper at summit..
which series QF-950 do you run? what did they change from their stock settings for your combo specifically?
#254295
03/15/09 09:32 PM
03/15/09 09:32 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I ordered 1 from them direct and they said some of the things that they would change is they plugged both power valves and square jet plus they richened the idle circuit and it is a Q series 950
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
