Re: Do these head gasket cooling slots look ok?
[Re: CompSyn]
#2542314
08/28/18 02:39 AM
08/28/18 02:39 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
CompSyn, could you shoot a picture of the other side of the original gasket at the slot? Here you go... Pic looks like a round hole on left and a slot, also maybe block had the hourglass openings not just a single round hole, or is it an optical illusion. Trying to figure out if narrow slots were designed for hourglass blocks. Can confirm max wedge also were stock with .375 gasket
[Re: 4406bbl]
#2542319
08/28/18 03:33 AM
08/28/18 03:33 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
CompSyn, could you shoot a picture of the other side of the original gasket at the slot? Here you go... Pic looks like a round hole on left and a slot, also maybe block had the hourglass openings not just a single round hole, or is it an optical illusion. Trying to figure out if narrow slots were designed for hourglass blocks. Can confirm max wedge also were stock with .375 gasket It’s apparent to me that the coolant was in a high acid state at some point. It caused a lot of corrosion including eating away at the steel freeze plugs and head gaskets. The original head gaskets had normal slots when new.
[Re: 70B5Cuda]
#2542904
08/29/18 08:50 AM
08/29/18 08:50 AM
Posts: 601 Mass
charge70
Mass
I have been chasing the cause of my 440 overheating problem here.....( https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2509662/1.html) .....and for a couple reasons, I've convinced myself that it had to be the head gaskets. I've been through all the normal stuff (180 t-stat, no t-stat, radiator check, installed spring in lower radiator hose, new coolant, new water pump, checked engine timing, new coolant temp sensor, different temp gauges (2), installed clutched fan (had a fixed fan when I got it), etc and nothing has helped. Also, the upper radiator hose barely has any coolant flowing through it; my survivor 69 Charger with completely original 383 has much more pressure in the upper radiator hose. I pulled the heads this morning and the saw a couple things. 7 or 8 pistons were kissed at one time or another.....but anyway, the cooling slots seemed suspect. They look way too small. What do you think-could this be the source of my problems? And does anyone have pictures of what the slots would look like? I've read that they were much wider on the original head gaskets. If anyone has modified the slots, does anyone have any pictures? Thanks The lack of coolant flow back to the radiator bothers me.Even if the slots in the head gaskets were to small,or even to big,you should still have good flow into the radiator.I think I would be looking at possibly the impellers on the waterpump are to far away from the back of the w.p. housing and there is a cavitation problem or possibly there is a rot hole internal on the pump housing and the coolant isn't making it into the block. There is a lot of big block Mopars out there running head gaskets w/the small slots that don't have overheating problems.I really believe the problem lies elsewhere.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 70B5Cuda]
#2543093
08/29/18 04:19 PM
08/29/18 04:19 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I can't see the pictures but the size of the slots are not your problem , there are thousands of big block mopars out there with the same head gaskets.
I have a friend that had a similar issue that nothing he did would fix, his engine was also .060 over ....
[Re: JohnRR]
#2543218
08/29/18 08:53 PM
08/29/18 08:53 PM
Posts: 729 Michigan
BlueRacer69
I have a friend that had a similar issue that nothing he did would fix, his engine was also .060 over .... I have to agree with John. I think at least part of the over heating issue you have is your .060 over bore. That much bore usually makes a 440 engine run on the warm side. Boring a 440 motor.060 over is great for a race engine that only gets run for a few minutes at a time, but not a street driven car. Is this a numbers matching motor to your car?
[Re: BlueRacer69]
#2543234
08/29/18 10:22 PM
08/29/18 10:22 PM
Posts: 1,066 Newton, KS
70B5Cuda
Newton, KS
I have a friend that had a similar issue that nothing he did would fix, his engine was also .060 over .... I have to agree with John. I think at least part of the over heating issue you have is your .060 over bore. That much bore usually makes a 440 engine run on the warm side. Boring a 440 motor.060 over is great for a race engine that only gets run for a few minutes at a time, but not a street driven car. Is this a numbers matching motor to your car? It is not the numbers matching block. I was just getting ready to sell the car and I can't sell it with an overheating issue.
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: 70B5Cuda]
#2543543
08/30/18 06:16 PM
08/30/18 06:16 PM
JohnRR
U.S.S.A.
I have a friend that had a similar issue that nothing he did would fix, his engine was also .060 over .... I have to agree with John. I think at least part of the over heating issue you have is your .060 over bore. That much bore usually makes a 440 engine run on the warm side. Boring a 440 motor.060 over is great for a race engine that only gets run for a few minutes at a time, but not a street driven car. Is this a numbers matching motor to your car? It is not the numbers matching block. I was just getting ready to sell the car and I can't sell it with an overheating issue. Not sure what to tell you then, you have a list of cars in your sig, try a rad out of another car and see what happens, or try that rad in another of your cars . What water pump and what water pump housing are currently on the engine? Does your radiatorhave a shroud ? Fan type, fixed or thermo coupled ??
[Re: Hemidavey]
#2543603
08/30/18 09:18 PM
08/30/18 09:18 PM
Posts: 4,674 Wichita
GY3
Wichita
My 440 is .080 over, no cooling issues at all. Its not the overbore, we have lots of customers cars at .060 engines and no issues. One engine we took apart due to overheating that was "rebuilt" had lots of crud in waterjacket but big issue was old core plugs pushed into the water jacket and left there! Originals are thinner cup shape and one made it up to passage closer to pump, very poor flow resulted. Some aftermarket pumps have very small impellers, some others are 1/2" away from the curved surface in the housing! Is there a big chunk of crud blocking passages in the radiator? Deleting the thermostat without some type of restricter nearly always overheats. Uh, NO!
[Re: Hemidavey]
#2543820
08/31/18 12:51 PM
08/31/18 12:51 PM
JohnRR
U.S.S.A.
My 440 is .080 over, no cooling issues at all. Its not the overbore, we have lots of customers cars at .060 engines and no issues. One engine we took apart due to overheating that was "rebuilt" had lots of crud in waterjacket but big issue was old core plugs pushed into the water jacket and left there! Originals are thinner cup shape and one made it up to passage closer to pump, very poor flow resulted. Some aftermarket pumps have very small impellers, some others are 1/2" away from the curved surface in the housing! Is there a big chunk of crud blocking passages in the radiator? Deleting the thermostat without some type of restricter nearly always overheats. What year is that block , I ASSuME you sonic checked it before going that far out?
[Re: 70B5Cuda]
#2543877
08/31/18 02:40 PM
08/31/18 02:40 PM
Guitar Jones
Most of these suggestions do not address the low flow issue and that is where the effort needs to be concentrated. Stop worrying about the over bore, the fan, the shroud, thermostat and any of that other stuff. Look for the issues that will cause a low flow condition and you'll find your problem.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
