Re: 2006 3500 4x4 f wheel bearings
[Re: mopars4ever]
#2542682
08/28/18 07:33 PM
08/28/18 07:33 PM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
Same here on my '06 2500. Mine wasn't real bad but don't think after all that work I would have wanted to fight pressing the hub and bearing out and a new one back in. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: cudaman1969]
#2542775
08/28/18 10:36 PM
08/28/18 10:36 PM
Posts: 1,032 Fitchburg, WI
BIGHOOK
Fitchburg, WI
Me three. '07 2500 HD 4x4. Left hub began chunking at 42,000k. I'm true blu Mopar and use OEM as often as I can, however, when that happened so early, I went aftermarket with hubs from NAPA. Made in USA with lifetime warranty. As previously mentioned, the bolt and steering method for removal is the best/easiest way to pop them out. Snap-On also makes a tool, kind of an extra long giant, solid socket specifically for hub removal on the Dodge 4x4's. Be sure and slather the Anti-Seize in the knuckle hole to facilitate future removal.
Due to the early hub failure and since I was opening it all up already, I went ahead and replaced the factory u-joints and ball joints with XHD Spicer joints and grease-able ball joints. Not long after was the factory TieRod/Steering Stabilizer recall for the HD 4x4's so that was replaced (no charge) at the dealer with a way beefier unit compared to the toothpicks that were up front it was built with!
[Re: cudaman1969]
#2543063
08/29/18 03:07 PM
08/29/18 03:07 PM
Posts: 8,271 fredericksburg,va
cudaman1969
fredericksburg,va
^^^^ I think the factory stuff is junk too. I'll look at all the parts when apart. I'm also getting the steering box-pitman arm stabilizer too.
At fifty grand for a new truck, that money can buy ALOT of parts and fuel!
[Re: cudaman1969]
#2543219
08/29/18 08:55 PM
08/29/18 08:55 PM
I_bleed_MOPAR
Buford, GA
When you get to the point of needing tie rod assy's I highly recommend using the '09-up steering linkage. (Got mine from RockAuto.) Tim
