kickdown and an a518 #2474235
03/30/18 05:15 AM
03/30/18 05:15 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Is it possible to use an a518 rh46 with a drive by wire engine harness from let's say Mopar or Holley?
Or do I need to use a cabble throttle body in order to make the kickdown work with an a518 rh46?
Re: kickdown and an a518 [Re: dickdale] #2474275
03/30/18 10:59 AM
03/30/18 10:59 AM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
I went thru this and you need one of these type setups http://bouchillonperformance.com/meta-product-kickdown-cable-kit or there's a factory cable box that some of the trucks used. That will get you the throttle valve hookup and the pedal sensor for the computer.
"It's funny how one project eventually leads (or forces) you into another one.
It's really just one endless project designed to induce insanity and bankruptcy."
Re: kickdown and an a518 [Re: dickdale] #2483369
04/15/18 11:46 PM
04/15/18 11:46 PM
BDW Online content
BDW  Online Content
Did you fab something up or buy from Bouchillon?
They make since stuff, but they are really proud of it too.
Re: kickdown and an a518 [Re: dickdale] #2483421
04/16/18 01:29 AM
04/16/18 01:29 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
When I did a 6.1/518 swap, I used a cable style throttle body and got a universal style cable and made my own brackets. I think the cable was actually for a motorcycle.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: kickdown and an a518 [Re: dickdale] #2486568
04/22/18 10:08 PM
04/22/18 10:08 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
I make manual shift valve bodies for the 518 & 46re . No kick down linkage needed. No TCM Needed. Shift pattern is P R 1 2 3 4
Re: kickdown and an a518 [Re: CRT] #2494629
05/11/18 03:01 AM
05/11/18 03:01 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I would quit the hobby before I paid those ridiculous prices from Bouchillon
Re: kickdown and an a518 [Re: dickdale] #2494821
05/11/18 05:11 PM
05/11/18 05:11 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Get a factory cable box off a 03 Ram..I scored one from the local pick and pull for $20. Like sixpackgut says, no reason to pay alot if you dont have to...
Re: kickdown and an a518 [Re: dickdale] #2542342
08/28/18 08:40 AM
08/28/18 08:40 AM
gregsdart Offline
gregsdart  Offline
I used Lokar kickdown and throttle cable kits on a 408 in a 65 Dart, not sure how it would work with the hemi TB, but worth looking into.
