66-67 Coronet/Satellite passenger mirror placement #2542158
08/27/18 08:55 PM
08/27/18 08:55 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Does anyone have measurements or a picture for the passenger side mirror placement on a 66-67 Coronet/Satellite ?
Re: 66-67 Coronet/Satellite passenger mirror placement [Re: 1970GTX] #2544009
08/31/18 10:10 PM
08/31/18 10:10 PM
Ohio
gtxmark Offline
gtxmark  Offline
Ohio
This was an option I believe....I would think it's the same as drivers side but all the '66,'67 mopars I have owned I have never had one with a passenger side mirror...
Re: 66-67 Coronet/Satellite passenger mirror placement [Re: 1970GTX] #2545507
09/04/18 06:45 AM
09/04/18 06:45 AM
crlush Offline
crlush  Offline
Passenger mirror will be placed farther back on the door, not same as drivers side, if you do you wont be able to see out of the mirror very well, dont ask how I know. Hopefully someone can tell just how far back it goes cause I dont know exactly how far back.
Re: 66-67 Coronet/Satellite passenger mirror placement [Re: 1970GTX] #2545982
09/05/18 02:10 AM
09/05/18 02:10 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
You look through the wing window to see both door mirrors on 66-67's. You look through the side glass to see the mirrors on 68-70.
I can measure tomorrow.
Re: 66-67 Coronet/Satellite passenger mirror placement [Re: NANKET] #2547978
09/09/18 03:39 PM
09/09/18 03:39 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
All I need are the measurements from the lower wing pivot, and the metal door lip to the Phillips head screw in the mirror.
