Cummins Engine Explodes on the Track - Full Story
#2542105
08/27/18 05:54 PM
08/27/18 05:54 PM
Posts: 7,144 my own world
theraif
my own world
Re: Cummins Engine Explodes on the Track - Full Story
[Re: theraif]
#2542233
08/27/18 11:15 PM
08/27/18 11:15 PM
Posts: 11,658 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Wonder how long it took to clean up the track.
[Re: theraif]
#2542235
08/27/18 11:16 PM
08/27/18 11:16 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
They need a condensed version where they show the footage and aftermath... I couldn't sit through the whole vid without skipping most of it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: theraif]
#2542263
08/28/18 12:23 AM
08/28/18 12:23 AM
fast68plymouth
So. Burlington, Vt.
6.16 in the 1/8........ at 6100lbs.
That’s pretty serious power.
[Re: theraif]
#2542297
08/28/18 01:28 AM
08/28/18 01:28 AM
Posts: 2,260 IL
furious70
IL
150mph from the logger as well? 158psi with the runaway fuel! 8200rpm when it broke rod bolts
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: theraif]
#2542441
08/28/18 12:48 PM
08/28/18 12:48 PM
Posts: 10,044 MN
JERICOGTX
MN
A 6.19 @ 120mph in the 1/8th is a mid nine second pass.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2542445
08/28/18 12:52 PM
08/28/18 12:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Anything that is given enough pressure will break and that was hitting 158 pounds of boost.. I guess they found the point to break
[Re: MR_P_BODY]
#2542477
08/28/18 01:53 PM
08/28/18 01:53 PM
Silver70
Rust Belt, SW PA
Anything that is given enough pressure will break and that was hitting 158 pounds of boost.. I guess they found the point to break The problem was the rpms when he put it in nuetral... not out of the ordinary for 150psi boost with a built cummins.
