Deciphering a build sheet #2542037
08/27/18 03:05 PM
08/27/18 03:05 PM
Canada
Mikeyrosie000 Offline OP
Canada
I’m trying to decipher my build sheet
According to the sheet from what I can gather line 2 says
E63 engine - 383 v8 single 4 barrel carburetor (8 cylinder) 335hp orange / 330hp painted blue
D32 trans - 3 speed auto (a727)
On line 4
I can’t quit make out if it’s 085 - 383 4 barrel w/ auto trans and heater ( blue painted and carter 330hp carb)
or 088 - 383 4 barrel w/ auto trans and heater (orange paintedengine and holly carb 335hp)
Proceeded by the next number on the line which is carb - 38 ... 4736s carter avs 1970 383 4 barrel auto trans....
I’m confussed as my matching vin on the block is on a painted orange block. Which to me would mean it’s the 335 hp with holly but why does it indicate a carter carb?
New to this and any help would be appreciated so I can find the right parts for restoring
Re: Deciphering a build sheet [Re: Mikeyrosie000] #2542071
08/27/18 04:22 PM
08/27/18 04:22 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
what kind of car?
1970 "badged" B & E-body muscle cars & Chargers with 383 4bbl automatics were orange "HP" engines
the rest were blue Carter 330hp versions
lots can happen over 48+ years - it could've been painted orange 30 years ago shruggy
Re: Deciphering a build sheet [Re: Mikeyrosie000] #2542079
08/27/18 05:06 PM
08/27/18 05:06 PM
Canada
Canada
But the vin when you search it is for a 8 cyl 383/330hp 4 barrel high performance
That’s why I’m so confused as the vin on the motor matches all other vins on car
Re: Deciphering a build sheet [Re: Mikeyrosie000] #2542080
08/27/18 05:07 PM
08/27/18 05:07 PM
Canada
Canada
It’s a 1970 barracuda bh23nob
Re: Deciphering a build sheet [Re: Mikeyrosie000] #2542094
08/27/18 05:38 PM
08/27/18 05:38 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Sounds like it should be a blue engine
Is it stamped HP on the pad by the distributor?
Does the barracuda have an axle package?
Re: Deciphering a build sheet [Re: 6bblgt] #2542096
08/27/18 05:40 PM
08/27/18 05:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The "N" in the VIN is simply 383 with 4bbl
Re: Deciphering a build sheet [Re: Mikeyrosie000] #2542097
08/27/18 05:42 PM
08/27/18 05:42 PM
Canada
Canada
3.23.rear Axel ratio sure grip Axel
Re: Deciphering a build sheet [Re: Mikeyrosie000] #2542101
08/27/18 05:47 PM
08/27/18 05:47 PM
Canada
Canada
thanks for the info...im looking at the pad and it looks like no hP
just says F383 then a funny symbol the X
Re: Deciphering a build sheet [Re: Mikeyrosie000] #2543101
08/29/18 04:30 PM
08/29/18 04:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No HP means it's not an HP engine, 383 4 bbl, the funny X is a Maltese cross, indicates an undersize .
http://www.moparts.org/Tech/Archive/motor/36.html
