Re: Neon 2.0L head replacement
[Re: njmopar]
#2542013
08/27/18 02:10 PM
08/27/18 02:10 PM
Posts: 21,433 It's a dry heat
gtx6970
It's a dry heat
Hello -
For those familiar with this job, do you think I am able to get to tensioner and keep belt slung around crank as I remove the head and replace. Planning on a reman head.
Also, are there studs or bolts on exhaust manifold? I am foreseeing broken bolts on old one as it comes off. Nope, gotta pull the lower timing cover Best i remember all the manifold to head hardware is bolts
[Re: njmopar]
#2542214
08/27/18 10:54 PM
08/27/18 10:54 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
Thanks. I'll do it the right way and not try to short cut. Looks like the puller is the same for my 3.5L in the 300M. Might as well make the tool investment.
Now the question is, and I am probably taking on more than I should. I am also changing out the front subframe. Hers has a fist size hole from the condensation from the a/c dripping on it and other questionable rust. It looks dangerous to me. Also the front end is beat and rusted to hell so changing out everything. The parts are cheap now and got an entire moog control arm and bushing kit and Monroe loaded strut kit for pretty cheap. So do I lower the engine assembly out the bottom and work on the head or do from up top? Might be nice to have the room to work. Or maybe I am just crazy.
[Re: stumpy]
#2542338
08/28/18 08:13 AM
08/28/18 08:13 AM
njmopar
Clinton, NJ
Sounds like you would be further ahead swapping cars. Checked on that already. Rest of car is in very good shape. She is 81 and only going to be driving so long. Plus she likes the size of the car. The $1k in parts and my labor is worth it, rather then buying something used and reliable. Nothing nice for under $3k. And yes, I am a bit crazy.
[Re: njmopar]
#2542438
08/28/18 12:42 PM
08/28/18 12:42 PM
njmopar
Clinton, NJ
I have been reading about those bolts breaking the body nut. And saw threads about the hole. I bought new ones and plan on heating the old one up and PB blasting the heck out of them before attempting to turn.
Do you think I should head it off and drill an exploratory hole above and spray in some PB? Then all I need is a body plug to seal.
I found a subframe on ebay that states to be rust free and in photos looks ok. We will see when it arrives. From the photo, looks to be miles ahead of what I have now. I wish I would have paid more attention to it over the years to prevent the rust. NJ road salt did it in. The new one will be soaked inside and out in fluid film. My new friend.
[Re: njmopar]
#2542457
08/28/18 01:08 PM
08/28/18 01:08 PM
gtx6970
It's a dry heat
Based on your description...i think I would
