Champion 3 roll radiator Shroud and 2-10 inch fans #2540933
08/24/18 04:20 PM
08/24/18 04:20 PM
CA.
RAY1969CARS Offline OP
CA.
Has anyone ever had any luck with theses ??? 69 dart with the 360 and a few bolt ons
If you ran this combo please feel free to give pointers
What are your thoughts on the shroud been so close to the back of the radiator and the shroud cover in the back of the radiator so much
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2540948
08/24/18 04:49 PM
08/24/18 04:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Run away from those fans. There is a big write up on Moparts by Feets about using a Mercedes fan. It works. Ford Contour fans can be made to work with the 22" radiator setups as well.
Don't be the exception.
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2541087
08/25/18 12:01 AM
08/25/18 12:01 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have had several of the Champion radiators. ALL have been twisted. A couple so bad that they weren't usable at all.
Go with the Mercedes fan and Howie's controller. I had that set-up on my blown Hemi Dart and it worked great.
Master, again and still
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2541158
08/25/18 08:21 AM
08/25/18 08:21 AM
Illinois
Sho Nuff Offline
Sho Nuff  Offline
Illinois
I have a similar set up in a Challenger with a 340. It's never run cooler, but I think the fans are junk personally. I plan on swapping out the fans or just going back to a mechanical fan.
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2541171
08/25/18 09:51 AM
08/25/18 09:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a Champion on my built 440 in a 65 Bbody.Fit good and runs at 180 or less all day.Been in for 2 years and happy with a 150 buck rad.I run a 18 inch stainless flex fan and its been in for 20 years.Rocky
Chrysler Firepower
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: DaveRS23] #2541175
08/25/18 10:07 AM
08/25/18 10:07 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
[quote=DaveRS23]I have had several of the Champion radiators. ALL have been twisted. A couple so bad that they weren't usable at all.
ive had 2 both twisted.my car is just a hotrod not for show so i just shimmed the rad to fit 520ci 10.5 comp. with stock fan runs nice and cool in the Fl. heat.
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2541205
08/25/18 11:56 AM
08/25/18 11:56 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
The Contour fans are awesome, but they won't fit a 22" radiator.
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: MarkZ] #2541235
08/25/18 01:07 PM
08/25/18 01:07 PM
moparx Offline
moparx  Offline
my opinion on that setup is two fold. number one, i'm not a "fan" [pun intended biggrin] of aftermarket fans. they never seem to live up to their CFM output, and NEVER last as long as factory units. second, those type of shrouds should, in my opinion, have a couple of trap doors that would allow airflow at speed to assist in the cooling process. just my blathering, your mileage may vary.
beer
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2541238
08/25/18 01:11 PM
08/25/18 01:11 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have that exact setup on one of my engine run stand engine setups, works fine. That said It never runs for more than 15-20 minutes at a go. I doubt I'd ever use it in an actual car, pretty low end stuff.
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: ScottSmith_Harms] #2541377
08/25/18 09:21 PM
08/25/18 09:21 PM
IN
ahy Offline
ahy  Offline
IN
I run a Champion radiator on a PU and works well. I run it with OE style shroud and mechanical fan (Ford).
I do not think that fan setup will make you happy. Running down the road at speed the shroud will block airflow. At a stop the fans will not pull enough air. A bigger OE spec single electric can work well. Ford Contour, Lincoln Mark III and Chevy HHR are some examples. I do not know about fit in your application.
I am sure you already know an effective electric fan will require upgraded alternator and wiring. Plan on a steady draw of 25-30 amps for a fan with enough airflow. Peak draw will be higher at startup.
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2541536
08/26/18 12:53 PM
08/26/18 12:53 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I ran the rad.and 2 10s on our deff non stock 426 hemi challenger. No shroud thou. It never got over 180 and could set and idle all day
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: toplescuda] #2541650
08/26/18 05:49 PM
08/26/18 05:49 PM
CA.
CA.
I was told by a friend that there’s two problems with the system first off the fans are weak second the shroud is almost like a barrier not allowing iair to flow through it almost put pressure On flowing air somewhat of a damn
Re: Champion 3 roll radiator Shroud and 2-10 inch fans [Re: RAY1969CARS] #2541673
08/26/18 06:53 PM
08/26/18 06:53 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I agree with a lot of the posts about that style shroud. While it may work for some, my personal experience was otherwise. I spent too much money trying to figure out why my car didn't cool efficiently. After two radiators, various flow restrictors and new fans my issue ended up being the shroud design. I ended up with a Flex-a-lite Black Magic setup. Everything's fine now.
As they say, "results may vary".
