Re: Indy aluminum blocks
[Re: fbs63]
#2541542
08/26/18 01:08 PM
08/26/18 01:08 PM
Posts: 4,067 Mo.
racerx
Mo.
Indy says the water blocks are good to 1500. I think Bob,the guy with the Procharged 69 Dart broke an early one but he was at 1800+ hp on alcohol. That's a lot I know of a ford fellow racer that runs a dart block with a turbo that run 1500 hp but he has concreted the block O-ring the heads/block , thought that was a bit much but.
[Re: racerx]
#2541543
08/26/18 01:10 PM
08/26/18 01:10 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
[quote=racerx]Really didn't what to do a aluminum block but there aren't a lot of choices there, but curios what type of power people were putting though them. Thought I read that Indy were going to start producing cast iron blocks in the next couple years hope there some truth to this [/quote First off unless your class requires it why in heck whould you pick cast iron over aluminum. That’s like picking lead over helium
[Re: pittsburghracer]
#2541670
08/26/18 06:46 PM
08/26/18 06:46 PM
Posts: 4,067 Mo.
racerx
Mo.
[quote=racerx]Really didn't what to do a aluminum block but there aren't a lot of choices there, but curios what type of power people were putting though them. Thought I read that Indy were going to start producing cast iron blocks in the next couple years hope there some truth to this [/quote First off unless your class requires it why in heck whould you pick cast iron over aluminum. That’s like picking lead over helium It's not a class car , round here it's a run what you brung type thing and I prefer to do a cast type block over aluminum . You have a KB block you willing to part with it?
[Re: racerx]
#2541710
08/26/18 08:03 PM
08/26/18 08:03 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
[quote=racerx]Really didn't what to do a aluminum block but there aren't a lot of choices there, but curios what type of power people were putting though them. Thought I read that Indy were going to start producing cast iron blocks in the next couple years hope there some truth to this [/quote First off unless your class requires it why in heck whould you pick cast iron over aluminum. That’s like picking lead over helium It's not a class car , round here it's a run what you brung type thing and I prefer to do a cast type block over aluminum . You have a KB block you willing to part with it? Aaaaaaaaa NO. 😂
[Re: racerx]
#2542469
08/28/18 01:39 PM
08/28/18 01:39 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Casting Iron blocks is the easy part. Getting someone to machine them is a whole other issue. They are hard on equipment and that's where the costs lie after the core boxes are done.
[Re: racerx]
#2542578
08/28/18 04:12 PM
08/28/18 04:12 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
How far off are we from getting Keith Black blocks off the shelf? I e-mailed a couple of there suppliers about a low deck block but never heard back...would it not be the best block for a say a 1500hp build currently?
A new iron curtain drawn across the 49th parallel
[Re: sasquatch]
#2542680
08/28/18 07:31 PM
08/28/18 07:31 PM
Posts: 2,460 Sydney,Australia
tex013
Sydney,Australia
More KBs are about 12 to 15 weeks out.The lowdeck will not be available for the future although that could change with PROVEN demand. It is true that several lowdecks were made for some of the back ordered pieces, but these were a total nightmare,and insane to produce from a cost standpoint. I have the first wedge that I have done from soup to nuts ready to put some fire in the hole in the next day or so. I will say SO far I have been pretty happy with the way it went together. NOt a total fire breather but motor should make around 880 to 900. We shall see and I will let you guys know what I find. Todd that would be good to see/hear Todd Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: sasquatch]
#2542689
08/28/18 07:47 PM
08/28/18 07:47 PM
67autocross
Manitoba Canada
More KBs are about 12 to 15 weeks out.The lowdeck will not be available for the future although that could change with PROVEN demand. It is true that several lowdecks were made for some of the back ordered pieces, but these were a total nightmare,and insane to produce from a cost standpoint. I have the first wedge that I have done from soup to nuts ready to put some fire in the hole in the next day or so. I will say SO far I have been pretty happy with the way it went together. NOt a total fire breather but motor should make around 880 to 900. We shall see and I will let you guys know what I find. Todd Thanks for the info... post the RB build if you don’t mind.
[Re: racerx]
#2542716
08/28/18 08:22 PM
08/28/18 08:22 PM
Posts: 201 Texas
Chief
Texas
1300 HP, 1050 tq @ 6800. Blown injected on Alky. 6th year on it no issues.
Dave Covey
