rebuilding 4 speed can gears between 2.47 and 2.66 be inter #2541195
08/25/18 11:24 AM
08/25/18 11:24 AM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
We are rebuilding a 2.47 ratio 4 speed and having trouble finding a second gear--Can second gear from a 2.66 ratio 4 speed be used in a 2.47 ratio--there the gear count (34)---what is different between the 2 gears--
Re: rebuilding 4 speed can gears between 2.47 and 2.66 be inter [Re: Dart6pak] #2541203
08/25/18 11:50 AM
08/25/18 11:50 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
In order to change any gear you would also need to change the bottom cluster to one with the corresponding gear. Since these are one piece clusters, I think you're out of luck.
Re: rebuilding 4 speed can gears between 2.47 and 2.66 be inter [Re: Dart6pak] #2541248
08/25/18 01:48 PM
08/25/18 01:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: rebuilding 4 speed can gears between 2.47 and 2.66 be inter [Re: Dart6pak] #2541775
08/26/18 10:59 PM
08/26/18 10:59 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Yup - as was said you have to swap the cluster and the gears between them. Not just the cluster, or just the gears.
