Re: Piston to head clearance
[Re: DusterKid]
#2540832
08/24/18 12:00 PM
08/24/18 12:00 PM
Posts: 4,206 New York
polyspheric
New York
Somewhat dependent on bore size and chamber shape, but after .060" the knock suppression is weak, at .100" it's about gone.
Boffin Emeritus
[Re: dogdays]
#2540984
08/24/18 06:16 PM
08/24/18 06:16 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
The effect still works in the roller 318s which have something like 0.080 piston to head clearance. No it doesn't. Working over the years, in a Chrysler dealership, there have been numerous software updates and half a$$ed fixes for 5.2's and 5.9's with spark knock issues. Maybe a thinner head gasket would have been a better fix.
[Re: DusterKid]
#2541070
08/24/18 10:58 PM
08/24/18 10:58 PM
polyspheric
New York
P-H is 2 different issues: quench (knock suppression) has a limited range of effectiveness, with a small bore and plug near the exhaust valve you may not need to be really tight - Jenkins reported minor pumping gains in a non-critical SBC by going up to .060". This may also be true of alcohol engines where high comp is safer. Squish is the turbulence and mixture homogenization caused by mixture being expelled from the tighter space and (if you're lucky) aimed at the plug - this is generally helpful even if very loose.
Boffin Emeritus
[Re: polyspheric]
#2541096
08/25/18 12:35 AM
08/25/18 12:35 AM
RapidRobert
My take: measured carefully (piston rock) I want .040"
