Ebody 4 speed OD conversion...questions
#2540683
08/24/18 12:24 AM
08/24/18 12:24 AM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
Hi all...trying to convert my 71 Challenger to a 4 spd OD car. Originally a 6cyl, 3 spd manual. Was a 360 AT when I got it. Now that I got the OD trans in...the linkage doesn't appear to have room. Anyone have this combo with pics you can share,please? Even ebody m/t pics would help. Thank you!
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
Re: Ebody 4 speed OD conversion...questions
[Re: 4boxers4]
#2540684
08/24/18 12:28 AM
08/24/18 12:28 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What linkage? Shifter? Clutch?
[Re: Supercuda]
#2540686
08/24/18 12:34 AM
08/24/18 12:34 AM
4boxers4
Heart of Ohio
trying to understand how to post pics. Hurst E body shifter, Ebody linkage, standard clutch
[Re: 4boxers4]
#2540690
08/24/18 12:40 AM
08/24/18 12:40 AM
RapidRobert
hit "edit" then hit "file mananger" then hit "choose file" then you can work on getting your pic to upload (not always easy). then after you get it "in there" then click "add file" then click "done adding files" then post everything.
[Re: Morty426]
#2540764
08/24/18 07:52 AM
08/24/18 07:52 AM
4boxers4
Heart of Ohio
Ok, I have the rectangles right and will try the layout you recommend tonite. When you mention a different 3/4 rod for $69, could you be more specific about which to use and from where? Thanks!
[Re: 4boxers4]
#2540791
08/24/18 09:47 AM
08/24/18 09:47 AM
Posts: 6,426 Abilene, Texas
fastmark
Abilene, Texas
Passon performance. It’s a specific rod for the e body od conversion.
