VVT and a Prefix or Jesel Distributor #2540035
08/22/18 02:50 PM
08/22/18 02:50 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Can it be done? I have to run a distributor to be legal. What are my options with a 6.4 block. I believe all of those are VVT blocks.
Re: VVT and a Prefix or Jesel Distributor [Re: Dragula] #2540088
08/22/18 04:52 PM
08/22/18 04:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yes all the 6.4s are VVT, I have seen kits to adapt them for to use the early non VVT cams and timing sets, you should be able to get that and run the distributor. I dont think anyone has anything to run a distributor on a VVT engine that still uses VVT.
Re: VVT and a Prefix or Jesel Distributor [Re: HotRodDave] #2540135
08/22/18 07:16 PM
08/22/18 07:16 PM
Dragula Offline OP
Dragula  Offline OP
Initially I was told the conversion won't work on a VVT block...
The guy I used to talk with has left the company, and I am not sure who to talk with. The person answering the phones there said she needed a translator to understand what I was asking.
Re: VVT and a Prefix or Jesel Distributor [Re: Dragula] #2540141
08/22/18 07:43 PM
08/22/18 07:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
upon re examining my blocks I dont think it will work, the tensioners bolt to the block different and the chain ends up further out so you can not use the early shallow cover. I have no idea how you would make it all work.
Re: VVT and a Prefix or Jesel Distributor [Re: Dragula] #2540321
08/23/18 09:20 AM
08/23/18 09:20 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
What Dave said ,you can not use the early cover on the VVT blocks, it will bolt on to the block but there isn't enough room for the phaser to fit under the cover.
I can't comment on the Jesel kit but the Preefix kit WILL NOT work on the VVT blocks...…...BEEN THERER TRIED IT < AND DOES NOT WORK.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: VVT and a Prefix or Jesel Distributor [Re: ric3xrt] #2540328
08/23/18 10:24 AM
08/23/18 10:24 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Cascar motor has a distributor. What block are they using?
Rick Talbot is the guy you want to talk to
Re: VVT and a Prefix or Jesel Distributor [Re: sixpackgut] #2540415
08/23/18 01:25 PM
08/23/18 01:25 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I've got one and it won't work on a VVT block.
They are made for early 5.7 and 6.1.
Matt
Re: VVT and a Prefix or Jesel Distributor [Re: sixpackgut] #2540499
08/23/18 04:21 PM
08/23/18 04:21 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Alum based off of the 6.1.
Re: VVT and a Prefix or Jesel Distributor [Re: ric3xrt] #2540579
08/23/18 07:34 PM
08/23/18 07:34 PM
Dragula Offline OP
Dragula  Offline OP
My project is going down hill fast...Anyone want to buy a set of ported heads?
So tired of the lack of ability to get parts. VVT I am told has been around for a long while now. To put one of these in the particular car I have, it has to have a distributor of some kind. The Jesel requires an external water pump and oil pump and is not high on my list at the moment.
Re: VVT and a Prefix or Jesel Distributor [Re: Dragula] #2540594
08/23/18 08:03 PM
08/23/18 08:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
wish I had the money for some nice ported heads.
Kinda stinks for the old school guys trying to run the new hemi, no distributor, carb intakes are really really expensive or they suck. I dont get the lack of usefull afordable parts for one of the best PR car engines ever.
Re: VVT and a Prefix or Jesel Distributor [Re: Dragula] #2540645
08/23/18 11:04 PM
08/23/18 11:04 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Why do you ned to run a distributor? For what class/org.?
Re: VVT and a Prefix or Jesel Distributor [Re: HotRodDave] #2540651
08/23/18 11:13 PM
08/23/18 11:13 PM
Dragula Offline OP
Dragula  Offline OP
I am currently tied to the rules and just trying to do somthing different. Coil on wire is not currently allowed.
Re: VVT and a Prefix or Jesel Distributor [Re: Dragula] #2540655
08/23/18 11:17 PM
08/23/18 11:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
what about like what BES did in the engine masters and run a distributor off a little belt drive thingy?
Re: VVT and a Prefix or Jesel Distributor [Re: HotRodDave] #2540827
08/24/18 11:50 AM
08/24/18 11:50 AM
Dragula Offline OP
Dragula  Offline OP
I am told I need to switch to a dry timing belt setup, yet the BES one looks like a stock cover...That's what I wanted to do...
Re: VVT and a Prefix or Jesel Distributor [Re: Dragula] #2540853
08/24/18 01:02 PM
08/24/18 01:02 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
That's what he did Stock cover.
