Re: VVT and a Prefix or Jesel Distributor
[Re: Dragula]
#2540088
08/22/18 04:52 PM
08/22/18 04:52 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Yes all the 6.4s are VVT, I have seen kits to adapt them for to use the early non VVT cams and timing sets, you should be able to get that and run the distributor. I dont think anyone has anything to run a distributor on a VVT engine that still uses VVT.
[Re: Dragula]
#2540141
08/22/18 07:43 PM
08/22/18 07:43 PM
HotRodDave
Kalispell Mt.
upon re examining my blocks I dont think it will work, the tensioners bolt to the block different and the chain ends up further out so you can not use the early shallow cover. I have no idea how you would make it all work.
[Re: Dragula]
#2540321
08/23/18 09:20 AM
08/23/18 09:20 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
What Dave said ,you can not use the early cover on the VVT blocks, it will bolt on to the block but there isn't enough room for the phaser to fit under the cover.
I can't comment on the Jesel kit but the Preefix kit WILL NOT work on the VVT blocks...…...BEEN THERER TRIED IT < AND DOES NOT WORK.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2540328
08/23/18 10:24 AM
08/23/18 10:24 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Cascar motor has a distributor. What block are they using?
Rick Talbot is the guy you want to talk to
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2540415
08/23/18 01:25 PM
08/23/18 01:25 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Rick Talbot is the guy you want to talk to I've got one and it won't work on a VVT block. They are made for early 5.7 and 6.1. Matt
[Re: sixpackgut]
#2540499
08/23/18 04:21 PM
08/23/18 04:21 PM
ric3xrt
Trumbauersville PA
Alum based off of the 6.1.
[Re: Dragula]
#2540594
08/23/18 08:03 PM
08/23/18 08:03 PM
HotRodDave
Kalispell Mt.
wish I had the money for some nice ported heads.
Kinda stinks for the old school guys trying to run the new hemi, no distributor, carb intakes are really really expensive or they suck. I dont get the lack of usefull afordable parts for one of the best PR car engines ever.
[Re: Dragula]
#2540655
08/23/18 11:17 PM
08/23/18 11:17 PM
HotRodDave
Kalispell Mt.
what about like what BES did in the engine masters and run a distributor off a little belt drive thingy?
[Re: HotRodDave]
#2540827
08/24/18 11:50 AM
08/24/18 11:50 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
what about like what BES did in the engine masters and run a distributor off a little belt drive thingy? I am told I need to switch to a dry timing belt setup, yet the BES one looks like a stock cover...That's what I wanted to do...
