Small Block SCAT Or K1 Forged Crank?
#2540472
08/23/18 03:26 PM
08/23/18 03:26 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Thought I'd post this question here since it's more of a performance part. Both Forged 4" stroke with 318/340 mains. It'll be in a Street and strip application making around 450 horses?... The price difference is actually less than $10 so that's a wash. Which would you buy? If it makes difference at all I have a set of K1 H-Beam rods I'll be using in it. Thanks for looking guys!
Re: Small Block SCAT Or K1 Forged Crank?
[Re: Jwilli500]
#2540476
08/23/18 03:30 PM
08/23/18 03:30 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I've been pleased w/ the Scat products I've used in the past. Very nice stuff for the price. Never used K1, but have heard they are decent quality also.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Jwilli500]
#2540552
08/23/18 06:34 PM
08/23/18 06:34 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Scat makes nice stuff and is still in business. Thats what i would use, and is in a 418 stroker i have in the works
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: dogdays]
#2540928
08/24/18 04:09 PM
08/24/18 04:09 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought two K1 cranks years ago off of Dan (Performance Only) during a Winter Special he had when the chevy journal cranks became available. I used The K1 crank and K1 rods with upgraded bolts and that assembly was rebuild 3 times over the years and was in need of its forth when it spun a bearing. That engine ran low 9.70's in my Duster and served me well. I will be using the second crank I got from him hopefully this Winter with some more compression, bigger cam, and hopefully run some 9.50's.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Jwilli500]
#2540951
08/24/18 04:51 PM
08/24/18 04:51 PM
B3422W5
Portage,michigan
I should have been more clear in my original post. Both are perfectly fine. Scat is still in business, K1 isnt, from my understanding. So only for that reason would i go Scat. Both will do everything you need
