New part, Cam checking plate #254027
03/15/09 01:10 AM
03/15/09 01:10 AM
AndyF Online content OP
AndyF  Online Content OP
I made one of these for myself a long time ago from billet. Lots of people have asked me if I would make more of them but I never did since they were so expensive to make. The other day I hit on a way to do the same thing that costs a lot less to mfg so I cranked out a small production run.
The plate bolts to the deck surface and it holds a dial indicator in line with either the intake or exhaust lifter. This plate only fits big block engines. You have to supply your own dial indicator.
Re: New part, Cam checking plate [Re: AndyF] #254028
03/15/09 01:12 AM
03/15/09 01:12 AM
You also need to fabricate a short pushrod to make it all work. I thought about selling short pushrods but there are just too many combinations. Flat tappets need a different pushrod than roller lifters, RB and B need different lengths, etc. I'd have to stock about 6 different lengths and it just gets too confusing and expensive to deal with.
Re: New part, Cam checking plate [Re: AndyF] #254029
03/15/09 09:04 AM
03/15/09 09:04 AM
NC
440Jim Offline
440Jim  Offline
NC
A 2" dial indicator has a long stem, and if needed a screw in extension can be used (indicator with screw in tips). You just need a lifter with a contact spot (or something sitting in the lifter).
Re: New part, Cam checking plate [Re: 440Jim] #254030
03/15/09 09:44 AM
03/15/09 09:44 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have a roller lifter & a solid lifter that has a bolt welded to it with the head of the bolt used as a flat surface for the dial indicator.Now if that plate is thick enough,you could also have another hole in the center that could be used as a piston stop for TDC calculations.Will be degreeeeeeeeeeeein a cam in GREEN MOPAR's roadrunner this week and I'll take some pics
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New part, Cam checking plate [Re: hemi-itis] #254031
03/15/09 09:32 PM
03/15/09 09:32 PM
I have made these plates with an extension so they'll hold a dial indicator over the piston. But then that adds cost since you need to make the plate thicker, or else use spacers to clear a piston dome. I also decided over the years to use a piston stop rather than a dial indicator to find TDC. The dial indicator method has problems when you have a long rod motor since there is so much dwell time at TDC.
Re: New part, Cam checking plate [Re: AndyF] #254032
03/16/09 01:45 AM
03/16/09 01:45 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Nice piece Andy. How much are they?
Re: New part, Cam checking plate [Re: AndyF] #254033
03/16/09 10:24 AM
03/16/09 10:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Andy, turn the plate around and put a bolt in one of
the holes, bolted down in the same holes and now its
a TDC stop
