Converter questions #2539315
08/20/18 11:04 PM
08/20/18 11:04 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
I currently have an ATI tree master but some of the teeth are broke causing a hard start and sometimes no start lol where is the best place to send it ?
Re: Converter questions [Re: 70dusterjohn] #2539350
08/20/18 11:49 PM
08/20/18 11:49 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
a t i
Re: Converter questions [Re: 70dusterjohn] #2539361
08/21/18 12:18 AM
08/21/18 12:18 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Jason at QuickDraw right in Ohio
Re: Converter questions [Re: calrobb2000] #2539366
08/21/18 12:28 AM
08/21/18 12:28 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Originally Posted By calrobb2000
a t i
Well if you send it back to ATI they will charge you for a complete rebuild on the converter. They cut off the whole face and replace it hence a full rebuild cost ---- DAMHIK
Re: Converter questions [Re: max_maniac] #2539555
08/21/18 01:32 PM
08/21/18 01:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
a t i
Seeing as how the OP’s car is running way off what it used to....... having the converter completely gone though may not be a bad idea.
Re: Converter questions [Re: fast68plymouth] #2539842
08/22/18 12:29 AM
08/22/18 12:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
a t i
Not a bad thought...
Re: Converter questions [Re: 70dusterjohn] #2540016
08/22/18 02:15 PM
08/22/18 02:15 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What starter I had that happen and it was the chinese Mancini starter held crooked by the blcck braking teeth. 440 of course.
Re: Converter questions [Re: 70dusterjohn] #2540027
08/22/18 02:35 PM
08/22/18 02:35 PM
crabman173
crabman173
ATI does things right
They build fantastic equipment--perfect workmanship and since they built it to start with and since you have some exact input about what car is doing they would be the ones to make more precise adjustments in the unit than others that may not know exactly what that combo was doing from the start
That is just my opinion and ideas
Re: Converter questions [Re: 70dusterjohn] #2540101
08/22/18 05:20 PM
08/22/18 05:20 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I have welded up some teeth before then file them back down to match the others. Pretty easy if there aren't to many of them.
Re: Converter questions [Re: Sport440] #2540104
08/22/18 05:25 PM
08/22/18 05:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree An old machinist's trick is to drill into the broken tooth, drive in a steel pin, build up the pin with weld and then grind/file the weld to shape.
Re: Converter questions [Re: 70dusterjohn] #2540166
08/22/18 08:52 PM
08/22/18 08:52 PM
Deerfield, Ohio
Deerfield, Ohio
Yeah I got a row of them... about 10 ..
Re: Converter questions [Re: 70dusterjohn] #2540168
08/22/18 08:53 PM
08/22/18 08:53 PM
Deerfield, Ohio
Deerfield, Ohio
And yes cheap mini starter broke the nose off of it and took out the teeth
Re: Converter questions [Re: 70dusterjohn] #2540195
08/22/18 09:44 PM
08/22/18 09:44 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Grind the side of the block and/or the starter until it sits square.
