Re: Converter questions
[Re: max_maniac]
#2539555
08/21/18 01:32 PM
08/21/18 01:32 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Well if you send it back to ATI they will charge you for a complete rebuild on the converter. They cut off the whole face and replace it hence a full rebuild cost ---- DAMHIK Seeing as how the OP’s car is running way off what it used to....... having the converter completely gone though may not be a bad idea.
[Re: fast68plymouth]
#2539842
08/22/18 12:29 AM
08/22/18 12:29 AM
Posts: 13,201 aZLiViN
J_BODY
aZLiViN
Well if you send it back to ATI they will charge you for a complete rebuild on the converter. They cut off the whole face and replace it hence a full rebuild cost ---- DAMHIK Seeing as how the OP’s car is running way off what it used to....... having the converter completely gone though may not be a bad idea. Not a bad thought...
[Re: 70dusterjohn]
#2540027
08/22/18 02:35 PM
08/22/18 02:35 PM
crabman173
crabman173
ATI does things right They build fantastic equipment--perfect workmanship and since they built it to start with and since you have some exact input about what car is doing they would be the ones to make more precise adjustments in the unit than others that may not know exactly what that combo was doing from the start That is just my opinion and ideas
