turn signal switch #2538910
08/20/18 10:47 AM
08/20/18 10:47 AM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
Where does someone find a turn signal switch for a 69 sattelite? Not just the cancelling cam , the whole assembly. Thanks.
Re: turn signal switch [Re: bbtrux] #2539015
08/20/18 01:44 PM
08/20/18 01:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked Rock auto?
Re: turn signal switch [Re: bbtrux] #2539021
08/20/18 01:54 PM
08/20/18 01:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
https://www.ebay.com/itm/Dodge-1967-1968...id=361894731556
https://www.ebay.com/itm/1967-1968-1969-Turn-Signal-Switch-NOS-MoPar-Chrysler-Plymouth-Fury-Dodge-Polara/360952352736?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D52935%26meid%3Deb3c7fa5d3514cd5a3b91f521774eaad%26pid%3D100005%26rk%3D5%26rkt%3D5%26sd%3D362406015268%26itm%3D360952352736&_trksid=p2047675.c100005.m1851
Don't be the exception.
Re: turn signal switch [Re: bbtrux] #2539052
08/20/18 02:46 PM
08/20/18 02:46 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Year one has one that is just like OEM, $50.00 M&H makes it, they also make awesome wiring harnesses.
Re: turn signal switch [Re: bbtrux] #2539204
08/20/18 06:54 PM
08/20/18 06:54 PM
cbusters Offline
cbusters  Offline
If you have a column shift Auto the aftermarkets will not work without removing the selector light permanently.
Re: turn signal switch [Re: bbtrux] #2539272
08/20/18 09:43 PM
08/20/18 09:43 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: turn signal switch [Re: cbusters] #2539599
08/21/18 02:40 PM
08/21/18 02:40 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Not true, the one from Year one is Identical to the original !!!!
here is a picture of one smile
Re: turn signal switch [Re: bbtrux] #2539622
08/21/18 03:21 PM
08/21/18 03:21 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Fust an FYI, I bought a NOS one for my 69 Road Runner years ago and the cancel cam has never worked right. It might just be a fluke but, you may want to save yourself some money and just get the YO turn signal switch.
Re: turn signal switch [Re: CSK] #2539710
08/21/18 06:27 PM
08/21/18 06:27 PM
cbusters Offline
cbusters  Offline
Great! Good to know.
Re: turn signal switch [Re: bbtrux] #2539712
08/21/18 06:32 PM
08/21/18 06:32 PM
P
Porter67 Offline
Porter67  Offline
P
Seems results will vary, ive never had a repop work correctly, but never a issue with a nos one.
The first repop sent me on a full day of checking wires, connectors, ect... not fun, never again.
Re: turn signal switch [Re: Porter67] #2539719
08/21/18 06:41 PM
08/21/18 06:41 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Same here. Ive heard enough issues with these repop switches I seek out NOS when I need one. They're not that hard to come up with
The only truly difficult one to find is the 1970 only switch
