SMALL BLOCK LIFTER BORE CLEARENCE #2539158
08/20/18 05:38 PM
08/20/18 05:38 PM
Queensland Australia
moparmacka Offline OP
Is 0.003” lifter bore clearence too much in a 59 degree solid roller application?
These bores are iron and not bushed.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539172
08/20/18 05:55 PM
08/20/18 05:55 PM
Washington
madscientist Offline
Washington
Too much for me.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539220
08/20/18 07:53 PM
08/20/18 07:53 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2
Too loose, leaks away oil pressure and allows side thrust.
Boffin Emeritus
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: polyspheric] #2539258
08/20/18 09:08 PM
08/20/18 09:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you decide to run it I would recommend taking the extra time to tube the block. After having an issue last year and seeing how much oil shoots around those roller lifters I will never prep another block without doing it. Even on a planned solid lifter built.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: pittsburghracer] #2539273
08/20/18 09:43 PM
08/20/18 09:43 PM
maryland
mhead Offline
mhead  Offline
maryland
How does the hydraulic lifters get by with out tubing the blocks?I understand they aren't going to see the rpm's as the solid roller but?My current car we tubed the block and all is good for four years now.Just freshened it and all good.I'm currently putting together another for son with solid flat tappet without it being tubed so very interested the post.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: mhead] #2539283
08/20/18 10:01 PM
08/20/18 10:01 PM
PA.
"Little"John
"Little"John
PA.
He said in his post that he’s going with a roller cam. Tubing the block works great with both solid and roller lifter cams.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: pittsburghracer] #2539292
08/20/18 10:23 PM
08/20/18 10:23 PM
maryland
mhead Offline
mhead  Offline
maryland
So is the idea to tube to just keep more oil to the bottom end?How many guy's use solid flat or roller with out tubing?I suppose it keeps extra oil of top of crank also.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: mhead] #2539303
08/20/18 10:38 PM
08/20/18 10:38 PM
PA.
"Little"John
"Little"John
PA.
How many guys? I’m betting quite a few because I am always hearing of guys that have oiling issues. I was shocked to see exactly how much oil was coming out of the lifter bores when we primed his engine with the intake off. Lots of wasted oil that could be used for rod and main bearing oiling. Never again for me. I will send out a block for cleaning and mag work then bring it home to tube.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: mhead] #2539306
08/20/18 10:41 PM
08/20/18 10:41 PM
Washington
Washington
Too many guys aren't doing the simple tube fix. Every solid lifter engine should have it done.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539390
08/21/18 01:21 AM
08/21/18 01:21 AM
I ain't sure how much clearance I had but it was too much & it made the oil psi drop dangerously low after a bit of running. I'm gonna tube that block/go with solids.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: RapidRobert] #2539437
08/21/18 07:08 AM
08/21/18 07:08 AM
PA.
"Little"John
"Little"John
PA.
Hopefully it works out for you but I think the added clearance will mess with lifter rotation. We put a used 610 lift roller in my sons 360 and it runs like a beast going 6.54@3200 pounds.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: pittsburghracer] #2539440
08/21/18 07:30 AM
08/21/18 07:30 AM
I think it is time to get the bores bushed.......
Just very expensive
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539553
08/21/18 01:32 PM
08/21/18 01:32 PM
P
Porter67 Offline
Porter67  Offline
P
Ive tubed blocks for others but myself, (running composit solids), have never needed to, im not sure if its because I start out with new blocks or very low use oem blocks with good lifter bores.
I know the uncovering deal is an issue for some but the couple very early 360 block I use have not been a problem, ive a mid 70-s 360 block that I didnt use because it would of been the one.
With the op being good all the time and main bearing always looking good on the winter inspection ive never really given it a second thought because its never presented a problem.
But the .003 is alot of clearance.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: pittsburghracer] #2539593
08/21/18 02:31 PM
08/21/18 02:31 PM
Good point! (& noted). Thank you.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539689
08/21/18 05:50 PM
08/21/18 05:50 PM
It would appear when Mopar machined their after market blocks they opened the bores to approx. 0.906” for the 0.904” lifter. This is ok for a flat tappet lifter however, most of the solid roller lifters available are 0.903” diameter, which is where the extra clearence is from. I guess they figure people building a solid roller will bush the block because of the uncovering of the oil gallery problem. I heard of this with the Mopar a Hemi blocks. Wonder if the 48 degree blocks are the same?
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539690
08/21/18 05:51 PM
08/21/18 05:51 PM
Tubing is not an option as I have pushrod oiling for T&D rockers.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539704
08/21/18 06:11 PM
08/21/18 06:11 PM
Washington
Washington
What block are you using? I have 3 X blocks, one of which was brand new and an R block and none of them has lifter bores that big.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539706
08/21/18 06:16 PM
08/21/18 06:16 PM
P
Porter67 Offline
Porter67  Offline
P
I was wondering what block hes using as well... not much would shock me if it were an R3 block.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: madscientist] #2539904
08/22/18 07:06 AM
08/22/18 07:06 AM
340 Siamese resto block. Pretty much 59 degree R3 with the valley machined for wet sump. Can’t remember the pn.
Re: SMALL BLOCK LIFTER BORE CLEARENCE [Re: moparmacka] #2539944
08/22/18 10:30 AM
08/22/18 10:30 AM
Washington
Washington
Well then that really sucks big time.
I'm going to dig out the R block and double check that again.
