Re: Changing World aluminum wedge to Hemi whats it take
[Re: Dodgem]
#2539293
08/20/18 10:24 PM
08/20/18 10:24 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
The top row of head bolts
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2539311
08/20/18 11:00 PM
08/20/18 11:00 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
the bosses are there raw for the inner head studs need machining and drilling . I'm more looking at the drain back holes.
[Re: Dodgem]
#2539321
08/20/18 11:12 PM
08/20/18 11:12 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Picture from when i was assembling have a need for hemi heads for mu bucket list Looks like you would have to plug the top row of head bolt holes then install the upper row of through holes for the Hemi Head studs, add clearance for the push rods and add water passages...at a minimum
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Dodgem]
#2539717
08/21/18 06:41 PM
08/21/18 06:41 PM
Posts: 2,632 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm not man enough to tackle that job. I would sell the wedge block and buy a hemi block.
2011 Drag Pak Challenger
[Re: W.I.N. Racing]
#2540025
08/22/18 02:32 PM
08/22/18 02:32 PM
Dodgem
Ontario, Canada
Picture from when i was assembling have a need for hemi heads for mu bucket list Looks like you would have to plug the top row of head bolt holes then install the upper row of through holes for the Hemi Head studs, add clearance for the push rods and add water passages...at a minimum Glad you pointed out the additional water. Thanks again. In the end will talk with Tim Banning at FHO before I start. Head gaskets should help as a template as well.
