Manual VB 727 line pressure
#253887
03/14/09 10:28 PM
03/14/09 10:28 PM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
Is there a prefered line pressure for a full manual non-transbrake VB ? I would like to set the pressure a little more accurate than the measurment method described in the kit. Just looking for a ballpark figure. The TV linkage is set for max pressure full time. Thanks, Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Manual VB 727 line pressure
[Re: 440Jim]
#253890
03/15/09 09:16 AM
03/15/09 09:16 AM
turbobitt
Southington Ct.
Thanks for the replies. This transmission is going behind a roller cam, 572" Hemi. I will check it today and if it is around 150 than maybe I'll leave it alone.
Allan G.
[Re: turbobitt]
#253891
03/15/09 11:05 AM
03/15/09 11:05 AM
Posts: 30,469 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I have never actually experimented with this ... but with the car I am working on now I will. I say it depends on what your race-car-combo is. Some might need to run 165 psi ... but with a car that does not weigh much, has better aero than a big-car and does not have a ton of horsepower ..... I think you can run A LOT less. PLUS ... running not-more-than-you-need line-pressure is EZier on the metal and rubber seals AND it would take less power to run way higher than necessary PSI. My combo will be a front-motored dragster ... that all I hope it will do is be a mid-9 second "fun car" .....zero maintenence .... "change the oil once a year". I am going to set my trans at 80 psi or so.
[Re: dOc !]
#253892
03/15/09 12:48 PM
03/15/09 12:48 PM
turbobitt
Southington Ct.
I check the line pressure this morning and it was around 95 PSI. I dropped the pan and removed the VB and shimmed the spring with about .200" worth of washers. The was some adjustment left but not much. The spring looks flimsy so I didn't expect much results. After reinstalling the pressure only cam up to 110 psi. I should also add that it didn't matter how much RPM, or frst, second, or third gear, pressure stayed steady. Car weight is at 4000 pounds. Engine should be good for 700HP. Allan G.
Post deleted by Defbob
[Re: turbobitt]
#253893
03/15/09 01:04 PM
03/15/09 01:04 PM
#253894
03/15/09 02:11 PM
03/15/09 02:11 PM
turbobitt
Southington Ct.
I've been looking for pressure regulator springs and can't find any. May need to call around tomarrow.
[Re: turbobitt]
#253897
03/15/09 05:24 PM
03/15/09 05:24 PM
dOc !
Florida STAYcation
If yours is OK with 700 hp and pulling 4,000 lbs ....I should be good-to-go with 50-60 psi.
[Re: turbobitt]
#253898
03/15/09 08:05 PM
03/15/09 08:05 PM
Posts: 16,929 NC
440Jim
NC
There is more to it than just line pressure, the entire trans build and valve body comes into play. For that big motor and heavy vehicle, I would want a valve body designed for at least 120 psi, and prefer 5 clutches in the front drum. Just my opinion. I don't know what valve body you have, but it sounds like a modified stock one. Call John at CRT and order one of his valve bodies.
If you really want to experiment, he might sell you one of his regulator springs.
http://coperacingtrans.com/
[Re: 440Jim]
#253899
03/15/09 08:39 PM
03/15/09 08:39 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
turbo, are you sure the pump is good and the bushings/sealing rings are working properly? Seems like a ton of preload to get it to work.
[Re: CRIKEY]
#253902
03/16/09 12:06 PM
03/16/09 12:06 PM
moper
Columbia, CT
I'm getting out of my league admittedly at this point. But it seems like if you can't get past 110 psi, steady or not, with 3/4" of air behind the preload plate, plus .220 of shim, it seems you have leakage somewhere in the system. Maybe John Kunkel or Cope can chime in on that.
