Re: turn signal switch
[Re: bbtrux]
#2539021
08/20/18 01:54 PM
08/20/18 01:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
https://www.ebay.com/itm/Dodge-1967-1968...id=361894731556https://www.ebay.com/itm/1967-1968-1969-Turn-Signal-Switch-NOS-MoPar-Chrysler-Plymouth-Fury-Dodge-Polara/360952352736?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D52935%26meid%3Deb3c7fa5d3514cd5a3b91f521774eaad%26pid%3D100005%26rk%3D5%26rkt%3D5%26sd%3D362406015268%26itm%3D360952352736&_trksid=p2047675.c100005.m1851
[Re: bbtrux]
#2539052
08/20/18 02:46 PM
08/20/18 02:46 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
Year one has one that is just like OEM, $50.00 M&H makes it, they also make awesome wiring harnesses.
[Re: bbtrux]
#2539272
08/20/18 09:43 PM
08/20/18 09:43 PM
Posts: 553 DE
Ply72rr
DE
[Re: cbusters]
#2539599
08/21/18 02:40 PM
08/21/18 02:40 PM
CSK
Pattison Texas
If you have a column shift Auto the aftermarkets will not work without removing the selector light permanently. Not true, the one from Year one is Identical to the original !!!! here is a picture of one
[Re: CSK]
#2539710
08/21/18 06:27 PM
08/21/18 06:27 PM
Posts: 784 Florida
cbusters
If you have a column shift Auto the aftermarkets will not work without removing the selector light permanently. Not true, the one from Year one is Identical to the original !!!! here is a picture of one Great! Good to know.
[Re: Porter67]
#2539719
08/21/18 06:41 PM
08/21/18 06:41 PM
Posts: 21,480 It's a dry heat
gtx6970
It's a dry heat
Seems results will vary, ive never had a repop work correctly, but never a issue with a nos one.
The first repop sent me on a full day of checking wires, connectors, ect... not fun, never again. Same here. Ive heard enough issues with these repop switches I seek out NOS when I need one. They're not that hard to come up with The only truly difficult one to find is the 1970 only switch
