brass gas tank sending unit float resolder? #2538758
08/19/18 11:39 PM
08/19/18 11:39 PM
md
mopars4ever Offline OP
md
Can the gas tank sending unit brass float be resoldered? I have one with gas inside. If I drain and flush out can it be repaired? If so what type of solder?
Re: brass gas tank sending unit float resolder? [Re: mopars4ever] #2538763
08/20/18 12:00 AM
08/20/18 12:00 AM
BDW Online content
BDW  Online Content
Yes it can, but most likely not worth the effort.
I had same issue and found that once it's bad enough to hold gas there's just too many holes to solder. I used normal a Radio Shack solder used for electronics.
New float is only $6-$8
Re: brass gas tank sending unit float resolder? [Re: mopars4ever] #2538783
08/20/18 12:37 AM
08/20/18 12:37 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ford part number coaz-9202-b $10 on amazon
Don't be the exception.
Re: brass gas tank sending unit float resolder? [Re: mopars4ever] #2538793
08/20/18 01:01 AM
08/20/18 01:01 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Just replace it with the plastic one and forget-about-it..
https://www.ebay.com/itm/Fuel-Sender-Flo...m4383.l4275.c10
Re: brass gas tank sending unit float resolder? [Re: Big_E] #2538814
08/20/18 01:47 AM
08/20/18 01:47 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
years ago i went to the hardware store and bought a tapered cork like would go into a old type thermos bottle,worked great!
my ladder of success is missing some rungs
Re: brass gas tank sending unit float resolder? [Re: rhad] #2538828
08/20/18 02:30 AM
08/20/18 02:30 AM
^^^ that's unique! it still read the same?
Re: brass gas tank sending unit float resolder? [Re: mopars4ever] #2539207
08/20/18 06:57 PM
08/20/18 06:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree use the Ford one.It will out last the car.i saved a bunch when I was working and replaced the senders in them.Works better than any others.Rocky
Chrysler Firepower
