440 spark plug wire size #2538615
08/19/18 06:12 PM
08/19/18 06:12 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Anyone know if 8.5mm was the factory spark plug wire size on a 1970 440?
Re: 440 spark plug wire size [Re: gregok] #2538652
08/19/18 08:01 PM
08/19/18 08:01 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Definitely not. They were pretty small to fit in the stock wire looms. Seems smaller than 7mm.
Re: 440 spark plug wire size [Re: gregok] #2538848
08/20/18 04:56 AM
08/20/18 04:56 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think it's 7mm but it might actually be a little smaller
Re: 440 spark plug wire size [Re: gregok] #2538978
08/20/18 12:49 PM
08/20/18 12:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Back in the day, 7mm was the first step up in size for performance plug wires; 8mm came later, larger sizes later still.
Can't recall measuring OEM wires back then, but I'd guess they were smaller than 7mm, and likely an SAE dimension. They seem in retrospect to have been pretty small and not as pliable as what we have now.
Re: 440 spark plug wire size [Re: topside] #2538987
08/20/18 01:00 PM
08/20/18 01:00 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Does anyone make 440 wire looms to fit 8.5mm wires or do I have to modify factory looms?
