Guess this piston #2538310
08/18/18 11:47 PM
08/18/18 11:47 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
This is a 383 I bought and the guy said it had never been run. It has been together for over 10 years just sitting in the guys garage. It is a nice old school build - 906’s, 509 cam, TM-6, Demon 850.
I have searched the internet and can’t seem to find any details on this piston. I saw one on Mancini’s site that seems to have the same shape of relief in the picture, but the description said it was a 5cc relief. I am just having a hard time believing that is 5cc relief. I am going to try to roll it on its side tomorrow to see if I can at least get close to measuring, but thought someone on here probably knows exactly what it is.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Guess this piston [Re: clovis] #2538403
08/19/18 01:47 AM
08/19/18 01:47 AM
It looks like a custom piston with additional valve notches cut into them shruggy
Re: Guess this piston [Re: clovis] #2538437
08/19/18 04:28 AM
08/19/18 04:28 AM
fill the reliefs flush with the surface with clay then roll it up out of there & with your burette filled up pretty high to say 60 CC with water, kneed/roll the clay into a long rope with your palms then drop it into the burette & see how far the water rises. It for sure looks way more than 5
Re: Guess this piston [Re: clovis] #2538451
08/19/18 08:54 AM
08/19/18 08:54 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Looks like a kb162 Kieth Black piston.
Re: Guess this piston [Re: DblOJoe] #2538468
08/19/18 10:57 AM
08/19/18 10:57 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
That was the first thing I thought too.
If you look at Summit it will have extra wedges cut out in them , but over the years they have changed the configuration around. Look at Hughes web site and they have a picture of the older version like the ones you have.
Re: Guess this piston [Re: clovis] #2538625
08/19/18 06:58 PM
08/19/18 06:58 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Telltale Keith Black pistons.
Re: Guess this piston [Re: clovis] #2538761
08/19/18 11:57 PM
08/19/18 11:57 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
KB 162, and it is rated 5cc relief. Basically a stock piston replacement. 8.6 comp with a 90 cc head, 10.2 with a 72cc head.
Re: Guess this piston [Re: clovis] #2538875
08/20/18 08:44 AM
08/20/18 08:44 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Thanks for the help, KB 162 it is. I was able to match up the picture on the Hughes site. I decided to measure and they are in fact 5cc relief.
'75 Plymouth Duster
Re: Guess this piston [Re: clovis] #2539203
08/20/18 06:53 PM
08/20/18 06:53 PM
CA
W
wyrmrider Offline
wyrmrider  Offline
W
CA
more compression than a Sealed Power- Badger, etc stock replacement "destroked" piston
most of those are/ (now were) Flat tops)
no quench with open chamber 906 heads- tough to make this combo ping proof but big cam should help- but you loose mid range torque (which is why it may not ping)
check those heads out for guides and ex seats- stock valves?
Re: Guess this piston [Re: Sport440] #2539465
08/21/18 10:23 AM
08/21/18 10:23 AM
an8sec70cuda Offline
iagree Put a set of them in the '70 383 HP engine I rebuilt 10+ years ago. Only set that gave any reasonable amount of compression. Still ended up decking the 906 heads down a good bit.
CHIP
'06 GMC 2500HD LBZ Duramax
