Re: older style MP aluminum Hemi head torque
[Re: torkrules]
#253843
03/15/09 10:44 AM
03/15/09 10:44 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I would be curious to hear other oppinions on this too. I was warned not to torque the valley studs to spec. as it would distort the intake runner and then loose sealing. This was from a racer with a lot of hemi experience.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#253844
03/15/09 11:02 AM
03/15/09 11:02 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Mark
Yup, Ive heard the same thing. I've also heard:
75 on the deck/65 on the valley 65 all around 65 on the deck and 35-40 on the valley
[Re: MIKECS]
#253846
03/15/09 11:25 AM
03/15/09 11:25 AM
torkrules
I'm neurotic
I'm neurotic
Your wright the valley studs are to be torqued to 40lb.
If you listen to the TDG's they will tell you torque them to 75.
DO NOT LISTEN TO THE TDG'S.
40LB THATS IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
And to complete the puzzle......the deck studs are torque to......(insert answer here)
[Re: torkrules]
#253847
03/15/09 11:35 AM
03/15/09 11:35 AM
Hemi Allstate
Mt. Eden Ky.
I was told to go 70 -75 lbs with moly on the stage v. I can't remember what I used on the MP heads I had. Mark
Post deleted by Defbob
[Re: MIKECS]
#253849
03/17/09 07:33 PM
03/17/09 07:33 PM
[Re: torkrules]
#253850
03/17/09 07:45 PM
03/17/09 07:45 PM
Posts: 642 New Jersey
Craig
New Jersey
I was going (successfully) with the reduced number on the valley studs until a couple years ago when I had just the heads freshened with valves, springs, and a deck cut, and kept getting bad leakdown numbers after a full power run. Deck on block checked out flat. Found gasket embossing rings weren't crushing down at upper part of circle (steel shims, 1970s aluminum heads). Went to same torque on valley studs as head bolts and got good seal. That was after about 4 sets of head gaskets and cleaning, intake and header surface cleaning and sealing, etc, each time with good leakdown readings until after the first full power run. So I recommend same torque at all points, like the original service manual calls for.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: MIKECS]
#253854
03/17/09 09:31 PM
03/17/09 09:31 PM
Posts: 2,175 Duloc
The Shadow
Duloc
I am glad you sleep all night. The valley stud torque has nothing to do with the block. The main issue is the seat in the head the more torque you put on the valley stud the more distortion is on the seat.
TDG = Typical Dode Guy
I have heard it affects both the block and head. That's one reason why world has increased the length of the valley boss on their new blocks.
[Re: MIKECS]
#253856
03/17/09 10:25 PM
03/17/09 10:25 PM
torkrules
I'm neurotic
I'm neurotic
The block thing can be a factor. I have seen two older original block crack the bosses when they were torqued to factory specs (75 lb.ft on the iron heads). The shop that was doing them reduced the torque on the inner studs to prevent this. This shop was also doing some of the dyno testing for Cummins when they were in Canada. They remember the inner studs being as tight as the deck studs even on the aluminum 528 engines.
Wow, what a can of worms!
[Re: torkrules]
#253857
03/17/09 10:32 PM
03/17/09 10:32 PM
#253858
03/17/09 11:38 PM
03/17/09 11:38 PM
Hemi Allstate
Mt. Eden Ky.
I don't mean to hy jack, and this is the same topic. What tool are you guys using for the valley stud twelve point nuts? I cannot find a 1/2" twelve point crows foot.
Mark
#253859
03/17/09 11:41 PM
03/17/09 11:41 PM
torkrules
I'm neurotic
I'm neurotic
So, which one of us is the TDG? Or, are we all TDG's?
I'd be a tPG (plymouth)
[Re: Hemi Allstate]
#253860
03/18/09 01:10 AM
03/18/09 01:10 AM
torkrules
I'm neurotic
I'm neurotic
Mark
Snap-on p/n FRDHI81. I use 9/16" 12 point nuts.
[Re: B G Racing]
#253862
03/18/09 08:35 AM
03/18/09 08:35 AM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Why torque a oem almn head different than an aftermarket head? Is it because the better deck(thicker) seals w/o as much torque? 40ft/lbs seems light, especally on a race motor? What are you differing on OEM style vs aftermarket?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#253863
03/18/09 08:50 AM
03/18/09 08:50 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I'am referring to the after market like an Indy head that has a bolt rather than a stud in the lifter valley.A bolt clamps differently than a stud,you are friction loading as well as clamp loading and may pull the threads as well as distort the floor of the intake.There is a redundency as far as friction loading with a stud and the stud thread hole in an OEM style is a through hole whereas the Indy is a blind hole and it's termination is part of the intake floor.
